Post by captincvmn on Oct 22, 2020 21:48:04 GMT -5
Tonight I added a bit of precaution to my scooter. I added emergency contact phone numbers and my name to the inside of my brain bucket. I wrote my GF’s number and my brother’s number. I then stuck them inside a plastic bag up under the webbing in the top of my helmet. Tomorrow I’ll add a small label to the underneath of the rear of the helmet saying I.D. inside. I hope nobody ever has to find it.
Post by FrankenMech on Oct 23, 2020 4:13:57 GMT -5
Hmmmmm, I should do the same with a note donating my body to science if it hasn't been cremated in the crash.
Post by aeroxbud on Oct 23, 2020 6:43:59 GMT -5
Post by centoventicinque on Oct 23, 2020 6:53:09 GMT -5
i've got a bit of cpr training , this is not a good place for that note:if you are not awake doctors are not going to remove your helmet before x rays because removing it if you have a broken skull may kill you
Post by captincvmn on Oct 23, 2020 7:59:26 GMT -5
i've got a bit of cpr training , this is not a good place for that note:if you are not awake doctors are not going to remove your helmet before x rays because removing it if you have a broken skull may kill you My primary concern was if I was separated from the bike or the bike was all mangled up that inside my helmet would hopefully remain with my body. After x-rays they’d eventually get it off. Certainly prior to the funeral. I probably could put a duplicate of it inside my wallet but there are many other papers in there.
Post by captincvmn on Oct 23, 2020 8:01:51 GMT -5
I like that. It’s better than my idea. I’ll look into getting that. Might even get one for my hard hat at work too.
Post by captincvmn on Oct 23, 2020 8:10:13 GMT -5
Post by 90GTVert on Oct 24, 2020 10:49:03 GMT -5
I've never seen those ICE tags either. Very cool idea. Should be standard equipment on motorcycle helmets. I was looking to see if they had them on amazon and found these too. Stickers with a QR code to scan for access to your info and ability to add more medical info if you need to share a lot of vital info. amzn.to/35BqJLk
Post by captincvmn on Oct 24, 2020 11:29:16 GMT -5
I like those scannable stickers also but I think I’d opt for the ICE tag first. Doesn’t require any smart phone device to retrieve the info. That’s the only downside I can see to the QR code version. Other than that I like it.
Post by captincvmn on Oct 24, 2020 11:34:02 GMT -5
Should be standard equipment on motorcycle helmets. Brent’s Allergies- Allergic to deer, may cause snoring Seriously though, as I motor around York, PA in the dark your deer accident goes through my mind every trip.
