Post by oldgeezer15 on Nov 1, 2020 18:03:38 GMT -5
I have a 2015 Wolf Blaze. I have just installed a 100cc BBK, A9 cam, 50mm head, new intake(stock),
20mm carb, new variator w/7g weights new stock clutch w,1000 rpm springs, aftermarket exhaust, and a Uni air filter.
its seems to run great except I notice a bog and lack of performance from 3/4 to full throttle. not sure which way to go
don't want to go the wrong way and mess up a good thing need some help from the pro's
harleyracer59
Scoot Veteran
I'd rather be lucky than good. Good takes practice lucky just happens
Post by harleyracer59 on Nov 1, 2020 19:10:40 GMT -5
are you building a 2 stroke or 4 stroke? i read a9 cam and guess its a slowpoke 4stroke. on slowstroke, does your 3/4 bog clear out or does it continue with more throttle/time? if its a 4 stroke, its either your needle height or main jet. try slide needle down 1 clip if it gets worse go 2 up (1 up from original position) and check if still an issue, do the same with main. try 1 up and 1 down in size. should put you on the right direction. if its carburetion.... could also be petcock fuel flow too. depends on the answer to my first question.
Post by oldgeezer15 on Nov 1, 2020 19:27:02 GMT -5
It's a 4 stroke I'll try carb I also have a new petcock I can try will do tomorrow and let ya know. thanks for the help.
fugaziiv
Scoot Veteran
Member is Online
Post by fugaziiv on Nov 2, 2020 11:34:19 GMT -5
I have a 2015 Wolf Blaze. I have just installed a 100cc BBK, A9 cam, 50mm head, new intake(stock), 20mm carb, new variator w/7g weights new stock clutch w,1000 rpm springs, aftermarket exhaust, and a Uni air filter. its seems to run great except I notice a bog and lack of performance from 3/4 to full throttle. not sure which way to go don't want to go the wrong way and mess up a good thing need some help from the pro's What is the actual bore of the BBK? Matt
