Post by sking3111 on Oct 20, 2011 22:55:43 GMT -5
Hello,I just got done installing a 47mm big boe kit on my beamer.really like the performance.I put a #90 jet a have a uni air filter to put on.6.5 roller weights and stock clutch. Does any body have any ideas about a good clutch set up ?and rollers?thanks alot!
Post by 90GTVert on Oct 21, 2011 8:22:08 GMT -5
I like 2000RPM springs in most of the 2Ts. Roller weight depends on the RPM the kit likes and gearing and personal preference to some degree. 4g worked well on my 70s. If you feel like it needs to rev higher, go lighter. If you think it revs too much now, use heavier weights. Make sure you upjet again if you go with the UNI. I don't think the UNI is worth all of the noise it creates, but that's up to you.
Post by speedy1125 on Oct 21, 2011 10:57:24 GMT -5
haha sorry my brain works in 4t, i didnt see this was in the 2t section
