Post by 94cy50 on Nov 22, 2020 6:35:06 GMT -5
On my 1994 jog the stock exhaust has a tiny screw that you can unscrew opening a small hole before the muffler. What is this for?
Post by geoffh on Nov 22, 2020 8:45:53 GMT -5
Someone may have drilled a hole? And the screw just fills the hole,leave it in there it has no performance use.
Post by Steve B on Nov 22, 2020 13:39:56 GMT -5
I too have seen this screw before on some older E-ton matrix beamer 2 stroke scooter exhaust.The bolt and hole comes from the factory. I do not know the purpose of it. I too would like to know why they did this.
Post by Zino on Nov 22, 2020 15:17:11 GMT -5
You can put a oxygen sensor in there and verify what the lean/rich ratio of the fuel is .
Post by 190mech on Nov 22, 2020 17:33:39 GMT -5
Lots of the old 2stroke motorcycles had them,they are there to drain the schmoo out of the pipe,then reinstall the screw...
Post by Steve B on Nov 22, 2020 18:45:17 GMT -5
Yes 190mech that makes a lot of sense. Not a bad idea on their part. Thank you for explaining.
