Post by Fox on Oct 21, 2011 19:59:21 GMT -5
Good video. Straight to the point with no distracting music in the background. :thumb:
Post by 90GTVert on Oct 21, 2011 20:14:42 GMT -5
That is a repost, but good stuff. Just while were on the topic, I have switched from plugs for the exhaust to a metal plate that I seal on the exhaust. They're easy enough to cut out of aluminum or steel, drill 2 holes to line up with the exhaust, done. The plugs are hard for me to get leak free sometimes in some ports. This way it works with any port shape.
Post by Fox on Oct 21, 2011 21:05:39 GMT -5
So you just use the exhaust gasket or what?
Post by 90GTVert on Oct 21, 2011 21:40:18 GMT -5
I usually just use a thin coat of sealant. Gasket would probably work fine.
Post by Fox on Oct 21, 2011 22:29:11 GMT -5
I'm gonna build a pressure tester now that I see how it works. Thanks Brent!
Post by Enviromoto on Oct 21, 2011 22:29:29 GMT -5
Cut a rubber gasket and reuse it over and over again.
Post by Fox on Oct 21, 2011 22:55:09 GMT -5
Great idea! You could bond the gasket to the metal with something so it's all one piece.
