Post by Deleted on May 8, 2012 23:54:14 GMT -5
Midnight is up for sale now. I cant decide if i want to use Yellow Fever to build the stroker..or a new black 2011 Boadiao with dual rear suspension using the long case dual shock motor i got from Fox with 13" 150 style wheel with a rear disc brake setup. Decisions Decisions. I dont like that wheel much and It wont match the front. I have been trying to find another Qingqi rear wheel. Found one in Richmond VA on a nation wide CL search but the guy never got back to me :/
Post by Deleted on May 9, 2012 0:03:55 GMT -5
A stroker with the Leo Vince exhaust sure would be sweet on this bike too though....but i just got done building this motor lol
Post by Deleted on May 15, 2012 0:33:29 GMT -5
Post by 90GTVert on May 15, 2012 7:09:45 GMT -5
Is there enough meat on the 52mm cylinder? I figured they're thin on the bottom where they enter the cases, but I've never had over a 50mm kit.
Post by Deleted on May 15, 2012 9:16:51 GMT -5
Is there enough meat on the 52mm cylinder? I figured they're thin on the bottom where they enter the cases, but I've never had over a 50mm kit. Oh yeah there is plenty enough. However, the rod would have to be machined to accept a +1mm pin (14 instead of 13).....the piston height for the 125 piston is 40mm vs. stock height of 34mm so the jug would have to be shimmed....and this would probably require a longer timing chain too. Then of course there is still the variator issue we have been exploring too. This would be an expensive build. BUT...I wonder how many other people in the world have a true 100cc 139qmb motor?
Post by 90GTVert on May 15, 2012 11:46:13 GMT -5
Piston weight would be a pretty big negative I'd think since it's that much larger and taller. Then you take the heavy piston and cut some meat outta the conrod. I dunno if having a one-off is worth it. I'd be really surprised if the power difference was worth it.
Post by Deleted on May 18, 2012 20:15:30 GMT -5
Ordered the first parts for this build today. Naraku NK100.65 52.4mm bore kit.
Post by Deleted on May 21, 2012 12:44:51 GMT -5
My LV exhaust will not fit the 2011 Baodiao with dual rear suspension because of that right side shock....so Yellow Fever is now the bike for this engine, which already has the look I want anyway.
jcoahran
89 zuma ii
Post by jcoahran on May 21, 2012 15:33:37 GMT -5
good luck! i cant wait to see some pics and vids!
Post by Deleted on May 23, 2012 18:26:20 GMT -5
Post by Deleted on May 23, 2012 18:29:20 GMT -5
Put the LV Titan on YellowFever today.
Post by Deleted on May 23, 2012 18:46:29 GMT -5
39mm, 52.4mm
jcoahran
89 zuma ii
Post by jcoahran on May 23, 2012 20:02:10 GMT -5
wow thats a HUGE difference!
Post by 90GTVert on May 23, 2012 20:45:10 GMT -5
Sweet BBK. ;D
Post by Fox on May 23, 2012 23:41:41 GMT -5
Are you gonna put that long case motor in that thing?
