cfn
Post by cfn on Oct 23, 2011 18:55:43 GMT -5
Well im done with the BBK so i'm putting a new 90cc 2 stroke onmy 05 Triton R4 from Parts for Scooters.Now any info on the 90cc please do tell.It will be used daily 40 miles round trip.I'm not looking to race it just want something that will run 35/45 cruise and top out low 50s.Thanks
Post by 90GTVert on Oct 23, 2011 19:56:11 GMT -5
cfn
Post by cfn on Oct 25, 2011 16:10:07 GMT -5
On the road again..................Man i wished id done this in the first place.Put 60miles on it today and never missed a bit.Gps had me cruising 38mph ill open it up after the brake in.It's all stock running a 85 main jet 5g rollers new stock pipe.
Post by 90GTVert on Oct 25, 2011 18:13:07 GMT -5
Nice, let us know what you think once you really run it!
cfn
Post by cfn on Oct 29, 2011 13:44:21 GMT -5
After ridding this week im glad i went with a new setup.Im cruising at 38mph and top out at 49 mph.Now im sure with some tweaking i could get more but im having to ride this everyday till Sept.After then ill do some playing around with but im going to change to a performance pipe.
Post by 90GTVert on Oct 29, 2011 13:47:45 GMT -5
I'm a big fan of the Phongeer pipe if you go with an exhaust. Another good option to gain some speed and acceleration is a variator. I've had good luck with the Hoca performance vari from PFS . More info on both of those in the Project 90 thread.
Post by tour96se on Oct 30, 2011 15:33:42 GMT -5
90gtvert, where can you find that phongeer pipe?
Post by tour96se on Oct 30, 2011 15:37:29 GMT -5
keep the updates coming, my zip is about due for a freshining up and I've been eyeballing either the 90cc/100cc
cfn
Post by cfn on Oct 30, 2011 16:11:11 GMT -5
Ill keep the reports coming.Anyone running a 90cc what should i be getting out of it?Thanks
Post by 90GTVert on Oct 30, 2011 17:41:35 GMT -5
I got the Phongeer exhaust from vtcycles.com . You'll have to email or call though, they don't show it on the site. What you're doing sounds pretty much like what you should expect stock.
Post by tour96se on Oct 30, 2011 23:22:00 GMT -5
do they make more aggressive cylinders for the 90cc or 100cc?
Post by 90GTVert on Oct 30, 2011 23:33:45 GMT -5
It seems like it goes mild then straight to wild. There are the standard kind of cylinders, then the Hoca 54mm is a little better in stock form than the typical stuff. Then the next kits I know of go all the way to Big Evo, 2FAST, MHR... stuff that costs a couple grand for the crank and cylinder.
cfn
Post by cfn on Nov 27, 2011 15:57:40 GMT -5
Just put 500 miles on the new 90cc....... Its running great tops out at 52mph i can now cruise at 35/40 mph up the bridges around here.For you guys using the BBK just get you a 90cc engine from Parts for scooters.com mine was $520.00 shipped in 3 days.
Post by 90GTVert on Nov 27, 2011 17:05:24 GMT -5
Sounds like that "big block" torque has made another fan. ;D :thumb:
