Post by kevinas on Jan 16, 2021 10:34:58 GMT -5
it's a 4t honda lead 100cc, everything on it works as it should, the only problem is the headlights, when i got the scooter, the headlight wires were chopped up, and i couldnt find any loose wires that would fit
does anyone have a wiring diagram for this scooter? cant find it anywhere
i tried connecting the green wire coming out of the bulbs to any other green wire, cause i believe that's ground
also theres a white wire coming out of the hibeam part of the switch and a white wire from the regulator, and the headlight bulb has a white wire, the regulator is really close to the headlight wires, would it work if i would connect the wire from the regulator to the wire in the bulb?
also there are 2 more wires- black wire on the lower light bulb and the ignition switch has a black wire coming out of it, you think it would work if i would connect those two?
and a blue wire coming out of the headlight bulb (which the hibeam lowbeam switch also has), what wire should i connect to that? should i just try and run the wire from the switch to the bulb?
i can post a pic a bit later
Post by snaker on Jan 16, 2021 14:14:10 GMT -5
There are some Honda manuals in the menu manuals at the left. See if any of them match your setup.
Post by FrankenMech on Jan 16, 2021 14:15:24 GMT -5
A generic wiring diagram should work. Most headlight circuits are pretty much the same on newer scoots.
