bluebob71
Post by bluebob71 on Jan 26, 2021 14:02:24 GMT -5
i have a long case 150cc gy6 and i seem to of got the wrong belt scoot feels way slower now any one have a good place to buy a new 1?
Post by fugaziiv on Jan 26, 2021 14:08:41 GMT -5
What size belt did you install?
Matt
bluebob71
Post by bluebob71 on Feb 20, 2021 2:32:38 GMT -5
835-20-30 same 1 that came off it but i went cheap on ebay but ya its not right i did end up getting 1 that works dunno wtf was wrong with that cheapo belt but ya wont be ordering from that seller again.
adam2
Post by adam2 on Mar 21, 2021 20:33:06 GMT -5
Make sure when you're tightening the variator nut that you're not tightening against the belt, the belt should have slack when you're tightening the nut. You create the slack by pulling one of the clutch plates towards you and pushing the belt towards the center of the clutch. There are videos that show how to do that.
Similarly, if you're tightening the clutch nut, don't tighten against the belt. Usually the belt is near the outer circumference of the clutch anyway.
