Post by adam2 on Jan 30, 2021 23:20:21 GMT -5
I never really learned the basics of lubing machinery, gears, hinges, bearings, etc. Is there a handy guide, something simple for people with SHORT ATTENTION SPANS like me? Nothing to open a can of worms or bring out too much discussion!
So, for example, I removed the starter clutch from the cvt area, cleaned it, then wasn't sure if I should oil it with engine oil, 90w gear oil, grease, or nothing. It's a gear that slides forward by centrifugal force to engage with the cvt gear, so it has to slide well, and also mesh worth other gears. I'm now thinking moly oil, but I don't really know!
Here are the basics I've found from some reading.
Grease and lube
Don't mix grease types, they may not be compatible and can react with each other to make a messy goop. Completely clean out old grease first.
White lithium grease. door hinges, drawer slides, cv joints. good to 370 degrees f
High temperature grease, often silicone based, for wheel bearings. Also useful for steering linkages, chairs, universal joints, suspension
Marine grease, resists water better
Dielectric grease, for electronic connections, spark plug boots, etc, protect from corrosion. Often silicone based.
Penetrating oil, (like wd-40, "water dispersant #40"), low-viscosity oils with additives that are specifically designed for one purpose: to infiltrate the tiny cracks between surfaces (such as screw threads), add lubrication, and break up rust. They are short term lubricants. Homemade: 90% vegetable oil + 10% acetone, shake before use. acetone is flammable, and will melt many plastic containers, use a glass or metal container to mix it, or buy an oil can.
Moly oil, 0.5 - 5 percent Molybdenum disulfide powder mixed with Industrial and Motor Oils or Synthetic fluids, use for all automotive and industrial gears, reducers, cams, etc
oiled bearings can last twice as long as greased ones (is this true?)
Grease and lube
