51cc
Post by 51cc on Oct 27, 2011 21:05:33 GMT -5
does anyone knmow if peugeot speedfight and honda dio manifolds line up. the bolt pattern fits. do stock manifolds from speedfight and honda dio match up, to the carbs. uh the pictures look like speedfight would turn in more, is there motor farther away from the mniddle of the motor? would using a speedfight airbox match up?
im thinking it might where the carb mounts be at a different angle or maybe the peugeot goes out further?
i want to use my stock airbox with an aftermarket manifold and carburetor.
Post by speedy1125 on Oct 27, 2011 22:11:30 GMT -5
do you have photos of what you have and what you want to use?
51cc
Post by 51cc on Oct 27, 2011 23:21:39 GMT -5
has anyhone ever done it? cause it looks the same. just wondering if i can use stock airbox. i mean, or a stock peugeot, whatever i dont care, injtake sucks.
Post by speedy1125 on Oct 27, 2011 23:28:46 GMT -5
i would think the stock airbox could be used.
51cc
Post by 51cc on Oct 27, 2011 23:31:16 GMT -5
Post by reveeen on Oct 28, 2011 1:52:28 GMT -5
There are a variety of "manifolds" that fit up to a DIO (I'm assuming this is what you are trying to get at). The trouble is not specifically the manifold, but is the pi55 poor reed block under that manifold, and the crappy small carbs (specifically that Honda bi-starter choke business) bolted to that manifold. If you are looking for stockish bigger to fit your DIO look to NH80, or NH125 (take it all, the reed block, the bi-starter, the carb, and the air box. But whatever you do it isn't going to work half as good as this: www.treatland.tv/OKO-26mm-reed-block-intake-p/oko-dio-reed-block.htm
51cc
Post by 51cc on Oct 28, 2011 2:22:25 GMT -5
yea but i can use any peugeot manifold becuae the bolt patterns lines up if i want to use an aftermarket filter. i got an af18 dio intake and manifold and carb. i dont really want over a 21mm carb.
Post by reveeen on Oct 28, 2011 3:13:20 GMT -5
So........ you use that manifold I linked you to, add on any spigot mount carb you like (in any size you like), and you are good to go, for $30 you aren't going to go too far wrong. For your $30 you get the manifold (that bolts on to your case), 4 petal reed block, gaskets, bolts, and carb rubber mount with clamps. There is even a port for your oil injection. win-win.
51cc
Post by 51cc on Oct 28, 2011 3:22:37 GMT -5
so it also fits a peugeot. ive said like i want a airbox connection. to my airbox, and stock. so im not using peugeot, im using dio and i want to use an aftermarket intake manifold, to fit my carb, or some other carb, and fit my airbox.
51cc
Post by 51cc on Oct 28, 2011 3:25:34 GMT -5
that intake is not a dio intake why im asking a question. dont bother me. oko isn't going to fit the airbox, im using dio, its differnt. dont you know that. didnt i say. i want to use an aftermarket intake that'll match. then the carb should still fit, and my airbox. my airbox has plenty of air. i dont want to use anything else.
Post by reveeen on Oct 28, 2011 6:02:47 GMT -5
that intake is not a dio intakeWould you like pictures?
51cc
Post by 51cc on Oct 28, 2011 14:01:59 GMT -5
what? my link isnt a dio? i know that thats why i asked. your picture isn't a dio? yes it is, ive seen that before i know it is, thats dumb. thats a ct intake, the taiwan everybody's got it with an extra big oko carb on it. and some aftermarket uni filter. your link isn't a dio? it says dio right in it.
i'm looking for an intake that will match my airbox. my airbox has plenty of airflow. i want to keep my airbox, they cost money. so would an aero80 or 125's intake match my carb, and airbox? would it be better to get their reedcage or an aftermarket like, malossi or some other brand? so think an adapter on the end of the flange to a rubber boot, would match a carb and my airbox?
the intake i took a picture of is actually an elite intake. honda elite. its extra and i took a picture of it.
found out bolt pattern was the same on peugeot, just if their manifolds match up.
51cc
Post by 51cc on Nov 8, 2011 15:18:57 GMT -5
hey so does anyone know if any aftermarket intakes fit a peugeot and let you use the stock airbox? if you use an aero 80 or 125 intake, and maybe reed, with an adapter, can you use the stock airbox? or any aftermarket? found out a dio will fit a peugeot.
