Post by milly on Mar 28, 2021 9:16:23 GMT -5
Picked this back up as use to be mine for £100. Makes easier for Yolanda get in and out of instead of micra. Towed it into garage area and used starter to get on ramp as headgasket gone and won't start. Oil now draining till tomorrow.
Post by Lucass2T on Mar 29, 2021 2:51:17 GMT -5
£100 is not too bad. Why did the head gasket go?
Post by milly on Mar 29, 2021 12:44:38 GMT -5
£100 is not too bad. Why did the head gasket go? I have no idea till stripped it down
Post by milly on Mar 29, 2021 12:48:28 GMT -5
Post by milly on Mar 30, 2021 7:59:58 GMT -5
Sump off oil don't look emulsified just like its not been changed for a few years.
Post by milly on Apr 7, 2021 12:44:51 GMT -5
Today cracked on with it engine blocked up and timed up ready to remove head tomorrow. Didn't know how much cars had changed since my day working on them with carbs. So many wires and sensors. Fiddle with wiring plugs and push pull prod and off they pop still no idea how ☺️ Bit murky with oil and water on the cams.
Post by milly on Apr 8, 2021 14:45:10 GMT -5
Head off got drop a piston out tomorrow see state of rings on no 3 cylinder slight scoring. If all good of to Carmarthen with head for pressure testing, skim and valves regrinding as number 3 the 4 valves have slight leak.
df41590
Post by df41590 on Apr 8, 2021 18:01:49 GMT -5
Milly it'd blow your mind, all the electrical crap on these new cars. Variable Valve Timing, Variable Compression, Electronic Thermostats, Automatic Emergency Braking, etc.
Looks like a daewoo engine there, i'll put my money on they didn't bother checking the coolant level and overheated it. Easy way to blow a head gasket real quick.
Post by milly on Apr 9, 2021 5:27:33 GMT -5
Indeed df41590 cooked and never changed the oil since I sold it to them. Rings are gummed up on number 3 so will take the rest out. Off to the engineers 30mile away to get pressure testing done and a skim if all good and valves ground in.
Post by milly on Apr 13, 2021 6:41:07 GMT -5
Clearing the workshop for them today found my ideal work aid
Post by aeroxbud on Apr 13, 2021 9:52:11 GMT -5
It won't be long. You can sit in that, and supervise the granddaughter, working on scoots.
Post by milly on Apr 13, 2021 15:03:14 GMT -5
That will be a pleasure to do I think 😀
Post by milly on Apr 19, 2021 3:54:59 GMT -5
Back from a 1,055 mile journey and now crack on getting the piston in with it's new rings.
Post by milly on May 3, 2021 12:17:26 GMT -5
Had time put head on today with all this rain
Post by milly on Jul 3, 2021 10:06:44 GMT -5
Pah! Plenty of parts to fit on scooter under the seat but was reminded to do the car on ramp. I had quietly forgotten about it for a while.
