Post by bajaguy76 on Apr 1, 2021 10:11:59 GMT -5
I have a 2020 tao tao 50cc. I've replaced the carburetor fuel regulator won't stay running fuel comes out through the back of the carb where the air filter is located. Starts for about 15 seconds then floods out. Help don't know what else to do
claydoh
Post by claydoh on Apr 1, 2021 13:11:44 GMT -5
Did you replace the carb to try and fix the problem, or is this happening the new carb specifically? Probably start here with tuning the carb: www.49ccscoot.com/faq/carbtune.htmlit gives you some starting points for adjustments that might help, then you can dial it in. Are there any other changes or mods you have on the scooter?
Post by 90GTVert on Apr 1, 2021 16:26:01 GMT -5
It sounds like you should check the float height. At least that's where I'd start. Float height setting is shown the link provided above.
Post by FrankenMech on Apr 2, 2021 17:10:31 GMT -5
The stock carb won't run without the air filter in place.
