Post by x7rocks on Apr 12, 2021 12:59:38 GMT -5
Looking for ideas on subframes for a rear facing carb
My main question is really more on the lines of "what's stopping me from cutting the bar and adding appropriate length bolts to hold the engine in place, and cutting the black bar above it as well"
Looking to hear your opinions or maybe a solution to my little problem. As one of my projects requires this as the factory carb location is incredibly hard to work with.
Post by aeroxbud on Apr 12, 2021 15:55:24 GMT -5
Post by moofus02 on Apr 14, 2021 20:12:38 GMT -5
I've seen the sub frame from a short case clone with rear facing carb used on a long case clone. Worked ok
Post by ThaiGyro on Apr 14, 2021 20:46:42 GMT -5
I would keep the OEM frame as is...It is not clear to me what you are pondering...if you have clearance issues...maybe an angle/dangle intake? Not a deal breaker for sure! You can have some fun if using an air-box...if not? You are in for crazy tuning anyway!
Post by x7rocks on Apr 14, 2021 20:55:35 GMT -5
I would keep the OEM frame as is...It is not clear to me what you are pondering...if you have clearance issues...maybe an angle/dangle intake? Not a deal breaker for sure! You can have some fun if using an air-box...if not? You are in for crazy tuning anyway! I do apologize for the incredibly crude drawing.but the idea was to cut this and have a metal plate take the spot and have long enough bolts to secure the two sides of the subframe mounts. I just don't know if the torque of the engine will make it shift in any way. But not entirely sure.
Post by x7rocks on Apr 14, 2021 20:56:23 GMT -5
I've seen the sub frame from a short case clone with rear facing carb used on a long case clone. Worked ok I have a short case subframe laying around. I could take some measurements to see if it works on the sr50
