Post by milly on Apr 20, 2021 15:11:47 GMT -5
Started taking this apart today try and source ignition switch so I can see what works and what doesn't, lot of broken clips where they had ripped the panels apart surprised they didn't use a screw driver must be easier for the thieves.
Post by aeroxbud on Apr 20, 2021 15:48:42 GMT -5
Let's hope your more successful with this than the WK. Mind you, this might be missing a camshaft too. 😂
Post by milly on Apr 21, 2021 17:34:20 GMT -5
Ordered the new ignition switch today 4 pin instead of 5 but a bit of head scratching over wiring diagram should help over the weekend at some point 😊
Post by milly on Apr 24, 2021 9:07:11 GMT -5
New switch wired in, jump pack on battery, easy start, turn key brmmmm . Gave it a while to warm up petrol smelt stale. Ticks over and revs well for a nasty evil 2 stroke. Just put the charger on repair mode see if battery can be saved, took off belt cover sort out kick start spring as not been assembled correctly, fresh petrol in, partially working with lights etc. Mend broken tabs and back together at some point. Now onto the ET4.
Post by geoffh on Apr 24, 2021 9:43:56 GMT -5
That's one abused scoot,but with the V5 (title) and an MOT it will show a handsome profit ,but please road test it and report on the beast ,going off other threads it,s a greyhound dressed as a basset  Geoff
Post by milly on Apr 24, 2021 11:56:48 GMT -5
Took it for a spin seems ok kick start working got some fangled exhaust on it technigas or something only spun it down the track and back but no splutters or splurges returns to tickover and sits purring away.
Post by aeroxbud on Apr 24, 2021 14:22:25 GMT -5
That's a result then. 👍
Post by milly on Apr 25, 2021 4:45:37 GMT -5
Bit more today. Just ordered brake lever put front panel on later if not get in way of brake lever removal. Battery recovered and all lights function.
Post by aeroxbud on Apr 25, 2021 4:47:20 GMT -5
They are a good looking scooter Milly.
Post by milly on Apr 25, 2021 6:30:50 GMT -5
They are a good looking scooter Milly. They are indeed and seem quite big, must look up the weight.
Post by milly on Apr 27, 2021 7:57:10 GMT -5
Post by milly on May 1, 2021 18:53:47 GMT -5
Back from work onward with the scooters Number plate on, quick once over , road test tomorrow and off for mot hopefully Tuesday.
Post by milly on May 2, 2021 8:03:05 GMT -5
Roadtest done impressed with the engine sped up to 45 mph on the GPS on my phone. Someone obviously tuned it well.
Post by geoffh on May 2, 2021 9:38:00 GMT -5
45 that,s impressive how quick does it get there? rev,s ? I am tempted,how much is that doggy in the window kinda thing.
Post by milly on May 2, 2021 10:42:52 GMT -5
45 that,s impressive how quick does it get there? rev,s ? I am tempted,how much is that doggy in the window kinda thing. Geoff It starts off kind of standard for a 2 stroke then feels like it's gone up a gear then really pulls fast to 40 then backs off a bit till it hits 45 and still holds revs for a bit more but running out of straight road by then but reckon with someone lighter than me at sixteen and a half stone may go a few mph more geoffh and I was not tucked down but sat upright on the flat.
