Post by milly on Sept 5, 2021 14:55:38 GMT -5
BONG! Round two, it's back again ☺️
Post by pinkscoot on Sept 6, 2021 10:35:52 GMT -5
Milly, you don't flip them you turn then into YoYo. You throw them out and back the come. Did he want the pots back?
Post by milly on Sept 6, 2021 11:31:44 GMT -5
Milly, you don't flip them you turn then into YoYo. You throw them out and back the come. Did he want the pots back? Lol no he quite happy for me to keep them ☺️
Post by milly on Sept 6, 2021 11:32:52 GMT -5
Only job to do is back bulb and idle speed which feels like a sticky cable.
Post by milly on Sept 7, 2021 6:31:40 GMT -5
Oh well new brake cable required. My fault I remember taking off the cable adjust nut with a impact ratchet and it twisted the cable. Bulb done now time for reflection
Post by milly on Sept 13, 2021 17:02:55 GMT -5
Thought I would check out why key lock when pushed would not open glove box. Took box off looked at lock and so much bodgery with a additional washer missing clips and glue I just put it back together.
Post by milly on Dec 28, 2021 6:04:10 GMT -5
As you know this bounced back to me for the third time and is now staying as got a couple of spare engine's. One of which will be done up as a 78cc once next month's paycheck arrives or I sell the Suzuki today. Ordered the Naraku sports camshaft and the Naraku cylinder kit will follow. Today I fitted the topbox I poached off the 125cc along with the mirrors and soon to be battery to fit and tray.
Post by aeroxbud on Dec 28, 2021 18:57:43 GMT -5
Will be interesting to see how the Naraku kit performs. The two stroke kits seem good value for the money.
Post by wiscootsin on Dec 28, 2021 21:36:04 GMT -5
i think this one wants to stay at home with you for good
Post by milly on Dec 28, 2021 22:17:39 GMT -5
Indeed it shall just about to head to Chichester in a bit
fudgerat72
Scoot Junior
Post by fudgerat72 on Dec 31, 2021 1:52:11 GMT -5
Post by milly on Jan 9, 2022 11:58:00 GMT -5
Another lesson learned, I changed fuel and vacuum lines for nice clear soft ones. Tested to make sure they sealed ok and just recently had bad start problem so today changed carb which in end didn't have to do was the fugging vacuum line when I sucked on it was not sealing so I checked and the line had pushed back off the wider part of pipe where it sits and was letting in air due to it being damn hard and not soft anymore. Oh well never mind 🤪💥
Post by jloi on Jan 9, 2022 18:41:04 GMT -5
milly , are your clear lines the silicone ones? I have some silicone ones on mine . I read a whole bunch of reviews before I got them and there are a lot of diff stories . I had silicone lines before I started with the wiring fiasco , when it was running and never had a problem with them . I originally had some from Parts for Scooters and the current set I got off Amacrom after reading a lot of reviews and searches comparing. and there's a local scoot shop that has some - sometimes . mine are real tite on all the nipples etc. . vacuum and fuel
Post by aeroxbud on Jan 9, 2022 19:41:36 GMT -5
milly , are your clear lines the silicone ones? I have some silicone ones on mine . I read a whole bunch of reviews before I got them and there are a lot of diff stories . I had silicone lines before I started with the wiring fiasco , when it was running and never had a problem with them . I originally had some from Parts for Scooters and the current set I got off Amacrom after reading a lot of reviews and searches comparing. and there's a local scoot shop that has some - sometimes . mine are real tite on all the nipples etc. . vacuum and fuel Milly will PM you his address. Can you send them overnight please. 👌
Post by jloi on Jan 9, 2022 20:36:01 GMT -5
I'll send them by seagull
