kevino
https://www.youtube.com/watch?v=04dSGwAssRA
Post by kevino on Jun 4, 2021 13:53:47 GMT -5
Where can I order a big bore kit for my 49cc Ice Bear?
Post by jstich on Jun 4, 2021 18:26:25 GMT -5
I have used parts for scooters with no problems.There are other reputable shops out there too.You could go the amazon/e bay route but that's a bigger risk.
Post by Deleted on Jun 4, 2021 19:36:44 GMT -5
Partsforscooters is great. Very good folks and prices reasonable.
I also like scooterworks, scootertuning.ca, get2it.
Have also used scooterpartsco, racingplanetusa, gy6store, dynoscooter, and scooterpartshop without issues.
With bore kits or essential parts, I would go with a reputable scooter parts specialist such as those above rather than Amazon, but that's just me.
kevino
Post by kevino on Jun 4, 2021 21:27:14 GMT -5
GY6 Cylinder Rebuild Kits Trkimal 100cc Big Bore Kit for 64mm Valve 49CC 50CC 139QMB Moped Scooter Engine 50mm Bore Upgrad... GY6 Cylinder Rebuild Kits Trkimal 100cc Big Bore Kit for 64mm Valve 49CC 50CC 139QMB Moped Scooter Engine 50mm Bore Upgrade Set with 6pin Racing CDI Ignition Coil Performance Spark Plug Clutch Spring 4.1 out of 5 stars 103
I found this for $79. How does gy6 differ from qmb?
Post by dan50 on Jun 9, 2021 15:31:53 GMT -5
A lot of people call 139QMB a GY6 generically.
If you're going the bigger BBK, make sure you put in a good aftermarket crankshaft. A stock crank can handle a 47mm BBK, but not the power of the bigger BBK kits.
Post by scooter7878 on Jun 18, 2021 5:50:47 GMT -5
I use ncy store there shipping is fast they have a lot of parts and customer service is good. Racing planet is good also but takes a little longer to get the parts. as for brands I prefer naraku and ssp-g but hoca and ncy are also good taida is good too but I find no one has a lot of stock in them
Post by fugaziiv on Jun 18, 2021 9:09:29 GMT -5
I use ncy store there shipping is fast they have a lot of parts and customer service is good. Racing planet is good also but takes a little longer to get the parts. as for brands I prefer naraku and ssp-g but hoca and ncy are also good taida is good too but I find no one has a lot of stock in them Food for thought, HOCA is now SSP-G. It was rebranded a few years back after HOCA closed. You can still find some HOCA branded product, but everything HOCA is moving or has moved to the SSP-G brand. Matt
Post by Deleted on Jun 18, 2021 16:47:42 GMT -5
+1 on SSP-G. Am running their 54mm cylinder on my 103. I also have their throttle cable and variator the Yamati. Very happy with quality of the parts. fugaziiv Thanks for the info on that. I noticed that as Hoca was disappearing SSP-G was showing up with a lot of the same part numbers. Nice to have confirmation.
Post by fugaziiv on Jun 21, 2021 10:52:48 GMT -5
+1 on SSP-G. Am running their 54mm cylinder on my 103. I also have their throttle cable and variator the Yamati. Very happy with quality of the parts. fugaziiv Thanks for the info on that. I noticed that as Hoca was disappearing SSP-G was showing up with a lot of the same part numbers. Nice to have confirmation. I was HOCA's sole US importer, and we own SSP-G... so straight from the horse's mouth I guess. Matt
kevino
Post by kevino on Jun 29, 2021 10:03:34 GMT -5
Thanks for moving me to this forum. What's the largest BBK I can get without machining the cases? I get Amazon ads for 100cc BBBKs. Should the BBK be matched to a larger venturi carb?
TIA,
kevino
Post by steve1297 on Jul 19, 2021 6:58:59 GMT -5
Thanks for moving me to this forum. What's the largest BBK I can get without machining the cases? I get Amazon ads for 100cc BBBKs. Should the BBK be matched to a larger venturi carb? TIA, kevino 52.4mm is the largest. And if you get a head with bigger valves, you can run a 24mm CVK carb for 150cc scoots, or even better, a 21 or 24mm OKO flat side carb, or Mikuni carburetor. You need a different throttle cable for the OKO or Mikuni, bit it's worth it
