Post by carolinamadness on Jun 14, 2021 21:48:51 GMT -5
so i have a 2017 TGB Exspress 50 it is not run because the engine is shot. i want to put a 4 stroke on it but not sure how much i would have to change out of the wiring. i assume i would need a new wiring harness but if anyone could help it would be appreciated. i cant figure out what engine is on it i know its a 50cc 2t but the manufacturer is unclear the only thing i could find is it says GA% on the engine.
Post by geoffh on Jun 15, 2021 15:34:25 GMT -5
Take a few pictures of the 2 stroke engine we might recognise it,can you define "shot" seized or not starting,swapping out to a 4 stroke would be complicated I would replace rebuild the 2 stroke before tackle a swap out.
Post by dan50 on Jun 17, 2021 2:27:16 GMT -5
Don't know if your engine is like a Minerelli type. On the 139QMB 4t's the engine mount is on the bottom of the engine and the 140QMB 2t's the engine mount is on the top of the engine.
Something to check out if the engine mounts are the same.
