Spal fan
Jun 18, 2021 14:58:34 GMT -5
via mobile
Post by badpaul88 on Jun 18, 2021 14:58:34 GMT -5
Can I run a spal radiator fan 3.4amp on a 12v 4ah battery
Post by 90GTVert on Jun 18, 2021 16:34:44 GMT -5
Depends how much it needs to run and how well the charging system works. I've got a 4" SPAL fan on my radiator, but I hardly ever need it. It draws quite a bit of power for a scoot's system, but usually it's just for being stuck at a long light or something and then it's back off. If you need to use a fan a lot, you may consider upgrading/upsizing the radiator(s) and making sure the rest of the cooling system is in good condition.
Post by badpaul88 on Jun 18, 2021 17:01:47 GMT -5
Only need it on when in traffic
Post by badpaul88 on Jun 18, 2021 17:03:53 GMT -5
And will be going strait to battery with inline fuse
