Post by scooter7878 on Jun 19, 2021 1:23:11 GMT -5
Up coming build if anyone has any suggestions or odds and ends I might wannt/ned/or be forgetting about feel free to let me know. I have a 139qmb long case extra I'm getting a ssp-g stroker crank,I'm going back and fourth between a naraku 52mm cylinder kit or a 50mm airsol domed piston kit one thing I'm not sure about is if its possible to use the airsol piston with a stroker by input if poss or if u think one or the other is better and why,a big valve head,49/17 gears aby suggestions on a different gear ,I already have a oko 21mm flat slide, modded exhaust,air filter,naraku variator, and a decent clutch which will eventually be upgraded,and I want to find a set of 12 inch rims that look decent but I'm not looking to spend 600 on rims any suggestions where to find a decent set of 12 inch rims would be appreciated along with any other info that I might need thanks in advance I'm already hitting 50 flat with my current set up 50mm bbk big valve head 10 inch rims and the above listed parts I already have no gear upgrade I'm hoping to push close to 60mph I guess we will see
Post by captincvmn on Jun 19, 2021 12:32:54 GMT -5
As far as I know your cylinder kit should be stroke matched to the crank. Perhaps I am wrong?
