Post by sToRm on Jun 20, 2021 19:39:06 GMT -5
Remove headlights from mount. Two bolts, one on each side. Unplug the stock bulbs from the harness. Take off the rubber boot and unclip the stock bulb.
Remove the stock bulb and insert the black plastic ring that came with the led bulb.
Clip the black piece into place.
Replace the rubber boot. Stretch it around the hole on the black piece. Trim it if needed.
Insert the led bulb and twist it to lock it in place. There are grooves in the black piece to help line it up.
Plug the new led bulbs into the harness and Bob’s your uncle.(ask a Brit)
