Post by scooter7878 on Aug 7, 2021 16:59:37 GMT -5
Is there any chance u have too much oil in it I've had a few times my friends changed there own oil and put too much in and had exactly same issues dry black plug and can't go over 20. It doesn't take to much over full to cause those issues. Also take the air filter off and drive it see if it's better one of the over fill oil issues the oil spat up intake and clogged his pod filter even after I drained oil to proper level it had same issue till I removed his air filter and it ran fine
Post by scooter7878 on Aug 7, 2021 17:00:29 GMT -5
Is there any chance u have too much oil in it I've had a few times my friends changed there own oil and put too much in and had exactly same issues dry black plug and can't go over 20. It doesn't take to much over full to cause those issues. Also take the air filter off and drive it see if it's better one of the over fill oil issues the oil spat up intake and clogged his pod filter even after I drained oil to proper level it had same issue till I removed his air filter and it ran fine . It only really takes about a 1/8 if a quart too much oil to cause issues
Post by scooter7878 on Aug 7, 2021 17:02:40 GMT -5
Is there any chance u have too much oil in it I've had a few times my friends changed there own oil and put too much in and had exactly same issues dry black plug and can't go over 20. It doesn't take to much over full to cause those issues. Also take the air filter off and drive it see if it's better one of the over fill oil issues the oil spat up intake and clogged his pod filter even after I drained oil to proper level it had same issue till I removed his air filter and it ran fine . It only really takes about a 1/8 if a quart too much oil to cause issues . When u check oil it needs to be warmed up and in high stand and u don't screw the stick in just till threads touch and pull it warm bike up shut off let it sit for a couple min on high stand and check if it's even slightly above cross hatch marks on stick drain some
vacationer
On Vacation
Post by vacationer on Aug 8, 2021 18:14:07 GMT -5
Welp, I pulled out the stick, wiped it off, stuck it back in without screwing, pulled it out - nothing. Screwed it in and pulled it back out - still nothing. No oil.
vacationer
On Vacation
Post by vacationer on Aug 8, 2021 18:22:42 GMT -5
False alarm! Forgot to put it on the stand. Tried again, oil level went about a third the way up the section with the hatch marks.
Post by scooter7878 on Aug 8, 2021 19:43:00 GMT -5
False alarm! Forgot to put it on the stand. Tried again, oil level went about a third the way up the section with the hatch marks. . Ok can u post a vid with sound of u riding it so I can hear what it sounds like u may have to post it on YouTube and just post the link it would help greatly to hear it
Post by scooter7878 on Aug 8, 2021 19:44:18 GMT -5
False alarm! Forgot to put it on the stand. Tried again, oil level went about a third the way up the section with the hatch marks. . Ok can u post a vid with sound of u riding it so I can hear what it sounds like u may have to post it on YouTube and just post the link it would help greatly to hear it I don't think the belt is ur issue that amount of lacking travel will take some mph off but I don't believe only 20 mph
Post by scooter7878 on Aug 8, 2021 19:46:12 GMT -5
. Ok can u post a vid with sound of u riding it so I can hear what it sounds like u may have to post it on YouTube and just post the link it would help greatly to hear it I don't think the belt is ur issue that amount of lacking travel will take some mph off but I don't believe only 20 mph have u tried driving it with the air filter tube off the carburetor if not try that
Post by scooter7878 on Aug 8, 2021 19:54:36 GMT -5
It might not be a bad idea for you to look on offer up or Facebook marketplace for a cheap scooter I buy whole scoots for 50 to 150 no title and I also find engines sometimes for 30 to 80 that I use for parts it probably wouldn't be a bad idea instead of playing around u could just be swapping parts without having to buy shit
vacationer
On Vacation
Post by vacationer on Aug 9, 2021 17:44:35 GMT -5
Nothing available on marketplace but I'll keep an eye out. Taking the filter off didn't change anything. Video: imgur.com/EHW75qfLet me know if that link doesn't work.
Post by scooter7878 on Aug 9, 2021 19:32:57 GMT -5
Nothing available on marketplace but I'll keep an eye out. Taking the filter off didn't change anything. Video: imgur.com/EHW75qfLet me know if that link doesn't work. what do the roms sound like at full speed and what is full speed now not normally
Post by scooter7878 on Aug 9, 2021 19:34:44 GMT -5
Nothing available on marketplace but I'll keep an eye out. Taking the filter off didn't change anything. Video: imgur.com/EHW75qfLet me know if that link doesn't work. what do the roms sound like at full speed and what is full speed now not normally like does it sound like it's winding out like if u drove a stick shift car 40mph in first gear or do the rpm sound low or limited down
vacationer
On Vacation
Post by vacationer on Aug 9, 2021 19:53:32 GMT -5
I get to full speed about 4 seconds into that video and stay at full until the end. About 15mph. Sounds healthy to me. No sputtering.
I'm not sure about the stick shift question since I've never driven one. It seems to me like RPMs top out much higher when the bike is on its stand, but that may be normal.
Post by scooter7878 on Aug 9, 2021 21:28:11 GMT -5
If ur rpm if high or normal and ur not hitting faster speeds ur issue is most likely in the cvt unless u have a brake dragging or something if it wasn't running correctly ur rpm would be lower sounding u wouldn't reach peak rpm with a badly running engine. I believe u have to be missing a issue in the cvt weather it's a clutch slipping or too light or possibly to heavy rollers/variator issue
Post by scooter7878 on Aug 9, 2021 21:31:58 GMT -5
If u have a way to get a rpm reading that would tell a lot it should be hitting at least 6500 rpm more like 7000 or above if it is ur issue is for sure in the cvt
