Post by wizard122 on Nov 4, 2011 22:35:27 GMT -5
Ok so I just put a jeted 20mm carb on my TaoTao t3 runs great but I noticed that the spacer between the head and manifold has a hole that is much smaller I was thinking about match porting them all together any thoughts? please advice. :scoot2:
Post by stepthrutuner on Nov 4, 2011 23:28:52 GMT -5
Do it. Std. Opr. Proc. You already know the reasons.
Post by 90GTVert on Nov 5, 2011 7:26:56 GMT -5
I agree with step, do it. ;D
I see you've been around for a while, but :welcome: to posting!
Post by speedy1125 on Nov 5, 2011 18:44:18 GMT -5
right on
Post by jmkjr72 on Nov 5, 2011 19:20:26 GMT -5
yep sop to port match anything you can as your building when you build from the ground up you should have more time in porting and matching then anything else
