Post by scooter7878 on Jul 19, 2021 17:16:09 GMT -5
Starting my build tonight I'm like a kid on Christmas 🤔😁 so my build is as follows. Ssp-g stroker crank,stg cylinder and 50mm airsal piston,now I have a bvh with 23 intake and 20 exhaust valves I also have a bbk head stock valves I'm not sure which one to use or even with extra gaskets or valve relief grinding if I can use the bvh with a stroker and domed piston any suggestions would be appreciated ,bibbi intake,oko 21mm flat slide carb, naraku intake spacer to taper the bigger intake to the smaller head port,for now a glixal racing clutch and bell I'm gonna modify the torque driver, naraku high speed variator and naraku aluminum drive face,bando kevlar belt,stg 49/17 gears,jml performance camshaft, naraku cdi,there's a nibbi high output coil on now but I'm going to modify a cop soon. Only thing I'm wondering is if the starter is going to be able to turn motor over I already upgraded the cables and I have a lawn and garden battery now which cranks my 50mm kit with no strain right now. Any other suggestions are welcome
Post by scooter7878 on Jul 19, 2021 17:20:46 GMT -5
Post by scooter7878 on Jul 19, 2021 17:21:49 GMT -5
Post by scooter7878 on Jul 19, 2021 20:23:58 GMT -5
Post by scooter7878 on Jul 19, 2021 20:25:40 GMT -5
Dissambled and getting cleaned I may even drop the crank in tonight so I'm ready to paint the block tmw
Post by CrankingWithCG on Jul 19, 2021 21:57:58 GMT -5
This thing is gonna rip a hole in the ground with all that grunt 😂
Post by scooter7878 on Jul 20, 2021 2:06:16 GMT -5
Post by scooter7878 on Jul 20, 2021 2:10:13 GMT -5
Got the crank in tonight now tmw gonna mount cylinder and see which head I'm going to wind up using checking ptv clearance and if needed I'm gonna try to notch the piston relief instead of extra gaskets I'm trying to keep the compression up 😁 once I get the ptv situation settled taking head and cylinder off to paint the short block and reassemble
Post by steve1297 on Jul 20, 2021 5:27:21 GMT -5
Did you get a new timing chain? Those bad boys stretch out when we add power.
Post by scooter7878 on Jul 20, 2021 6:37:59 GMT -5
Did you get a new timing chain? Those bad boys stretch out when we add power. . I sure did got a timing kit only thing I didn't get that I wanted to do is gear box bearings but that can be done later
Post by Deleted on Jul 20, 2021 12:57:11 GMT -5
Not a stroker, but definitely needs some balancing.
Post by scooter7878 on Jul 20, 2021 20:38:38 GMT -5
Post by scooter7878 on Jul 20, 2021 20:41:02 GMT -5
So I mounted the bvh and used play doh to check clearance and there's plenty of clearance which makes me happy so now cylinder coming off for the paint
Post by scooter7878 on Jul 21, 2021 4:13:41 GMT -5
Post by scooter7878 on Jul 21, 2021 4:20:10 GMT -5
Well I worked through the night got it just about ready to drop in the scoot just got a few odds and ends to square up tomorrow. I'm exhausted gotta quit for tonight but I'll be back on it in am. Gotta say when I turn it with plug in it feels like it's making hella compression 😁. I'm really happy with how it came out everything went smoothly I was able to use the bvh with no extra gaskets. The squish is real ha🤔 can't wait to run it I got some Lucas break in oil to run the rings in. I'll post a start up vid
