Post by reyrey on Jul 20, 2021 9:47:25 GMT -5
Can I use the regular size Naraku clutch springs In the polini 3 adjustable clutch? The polini 3g springs are much smaller but I was able to get the bigger springs to fit in place, it just took a little more effort. They seem to be fine, then again I’m not able to watch this thing actually spin and do work. Looking for a little advice before I find out the hard way. Thanks!
Post by aeroxbud on Jul 20, 2021 10:06:22 GMT -5
Polini use a different size spring to most clutches with their 3G clutch. It's only about 10 bucks for a set of three springs.
df41590
Post by df41590 on Jul 20, 2021 11:32:13 GMT -5
No they won't work. The shoe has a chance of hanging up on the hook part of the spring that pokes through causing the clutch to stay engaged. I found that out the hard way.
Post by Zino on Jul 20, 2021 17:27:36 GMT -5
I just went through ths weekend On my NCY clutch the polini springs fit but would hang up occasionally like a stuck rear brake .
So Springs are cheap buy the correct ones .
micky
wrenching on something
Post by micky on Jul 27, 2021 4:25:25 GMT -5
This is good info because im picking up a 3g today for only 30$. And i thought it used standard springs, Will make sure to get the appropriate springs for it now. Ty
