loosegrit
Too much work. Hope for another scooter run Oct 2015.
Post by loosegrit on Nov 5, 2011 21:37:12 GMT -5
Mirror Extention Plus  1 - 1/8" x 2" x 36" Alumium Flat Stock 2 - Door Jam Bolts ( hold 2 x 4 across door jams ) 2 - 2" x 1/8" L-stock Remove the mirrors, with mirror bolt, mount door jam bolts on scooter. Then mark where to drill holes for L-stock can connect alumium stock to the door jam bolts. Before assembly. You can paint the parts to match your scooter or the pieces can be polished and clear coated.  As you can see, simple assemble and after the mirror extention is made, possibilties are unlimited what you can do. In the past the extentions have protected my throttle and brake handles when the scooter has fallen over.  The dual sided turn singals are great for visiblity and you almost never forget to turn them off.
