Post by speedy1125 on Nov 3, 2011 15:01:54 GMT -5
I will be upgrading/assembling a 2011 50cc QT3 identical to this one:
Remove the cardboard and unbolt the metal frame 'crate'. Save the nuts and bolts, they are identical to many on the bike so you can use them should you lose any
This bike will have the following upgrades:
High Performance:
50mm Big Bore Kit (specifically 82cc but engine sizes are always rounded up to whole numbers for the most part. I will be referring to 47mm bore as 80cc, 50mm as 90cc, 52mm as 100cc.)
95/32 Carb Jets
Free Flow Air Filter
Timing Advance, No-Rev Limit Ignition
Tuned Transmission (5.5g rollers, Increases operating RPM into Max HP and Torque Range)
Reliability:
Replace stock drain plugs with magnetic drain plugs (Engine and Gearbox. Prolongs bearing life.)
Replace stock fuel lines, vacuum lines and fuel filter with high quality lines, filter and band clamps.
Replace stock tire valve stems with racing 3/4 inch metal valve stems with metal caps
Replace stock drive belt with genuine Gates Premium belt
Replace stock spark plug with genuine NGK plug
Replace stock glass fuse with automotive type blade fuse and water resistant holder
Exhaust painted with 3 coats high temp automotive paint to prevent rust
Better hardware used in areas where factory fastening has proven to be insufficient.
Step 1:
Lay out some cardboard the crate came wrapped in to use as a place to lay bodywork. Appoint a good friend to stand guard
Disassemble down to the frame. Be patient with the body panels! they are thin and fragile. Use 3-in-1 household oil on places where they are hard to separate. This helps when reinstalling as well. every component you remove put the screw/nut/bolt back in its journal after you remove the component. This way you will not have the fasteners laying everywhere getting mixed up and lost . Another method is to use baggies and label them with masking tape tags ect..
Remove wiring harness for inspection and modifications. Inspect frame for rust. Use sandpaper or wire brush on any rust and spray with black paint. Remove engine (if you are installing a Big Bore Kit).
High Performance:
95/32 Carb Jets
Reliability:
Step 1:
