Post by crazytaida on Aug 15, 2021 19:36:19 GMT -5
I purchased the Taida 61mm with 1mm dome top forged piston for 157qmj short case. Also have the 28 mm 23 mm stainless steel Taiwan performance head. Might sound kind of stupid but this is my first Taida 1mm dome top build and I'm curious if I should grab a +3 crank and a A9 cam? Curious if anyone has ever gone down this road and if it will all bolt together and turn over? This is welded up to a 2003 tao tao pony...lol
Post by crazytaida on Aug 15, 2021 19:48:08 GMT -5
Post by crazytaida on Aug 15, 2021 19:55:00 GMT -5
. Lol...
Post by scooter7878 on Aug 16, 2021 0:55:53 GMT -5
Boy that's gonna be sweet have u used any tadia products before? I'm building a 150 up for my buddy I been going back and forth between getting naraku or TD. I can tell u I put a stroker in my 139qmb with a airsal domed piston I saw on line a lotta ppl saying they had piston to valve contact and they using double gaskets and still couldn't get out cleared. I did not have to use any extra gaskets at all I installed cylinder and piston and packed playdough in valve reliefs installed head and torqued loosened up valve adjusters some to give some leaway turned motor by hand a few times removed head and cut playdough in half at valve relief and I had plenty of clearance my 50 cc I'm hitting 55 flat ground and 0 to 40 mph in 9 and half to 10 and a half seconds. I can tell u the stroker made a world of difference from before same 50mm cylinder no stroker. The power is insane from a 50cc. I'd for sure use a flat slide carb on that set-up that makes a huge difference from a cvk style carb. I know they also make spacers for the gy6 in different sizes to aid in ptv clearance. Right not my buddy's 150 is hitting 65 mph flat ground I've hit 69 down hill and 0 to 40 in 6.5 second. As of now he's got a performance exhaust,26 mm round slide carb,ssp-g cvt kit,and a 155bbk stick head stock gears and a cheap Amazon camshaft. I'm saying go for stroker bro that thing gonna rip
Post by scooter7878 on Aug 16, 2021 0:57:43 GMT -5
Sry correction I adjusted valves to no lash when I checked ptv clearance to be sure if the valves got tight after use I wouldn't run into ptv contact
Post by scooter7878 on Aug 16, 2021 2:29:15 GMT -5
Post by scooter7878 on Aug 16, 2021 2:30:32 GMT -5
Post by scooter7878 on Aug 16, 2021 2:41:39 GMT -5
My qmb build it's been together about a month now. 50mm airsal piston and stg cylinder,bvh 23 mm intake valve 20 mm exhaust,jml performance camshaft,oko 21mm flat slide carb, naraku hs racing variator 7g Dr pulley sliders,bando kevlar belt, Amazon cheap junk clutch and bell, stock exhaust gutted and packed with steel wool,bibbi intake and air filter, naraku cdi and coil,43/17 gears,ssp-g stroker crank, nibbi aluminum throttle grip. I'm super happy with how it came out it runs great I was as fast as my buddy's 150 with exhaust and 26mm slide carb till he got a cheapo 155cc cylinder and cam from Amazon. Now he blows me away lol
