Post by Scootrific on Sept 8, 2021 9:17:50 GMT -5
So, It has been some time now, after my last post. I decided to buy a normal high quality scoot this time and ditch the Chinese POC scoots for good. I did choose this lightly used Aprilia SX50, with some mods and restrictions removed. I did let the CEO put on the secondary mirror for safety. It had only left side on and no right mirror. They even swapped the spark plug and the choke needed also fixing, because it did got stuck.
Differences with the standard model: stronger and better shock absorbers (both front and rear) aluminum rear swing with link system, hand guards, handlebar is reinforced
Specs: Engine displacement – 80cc (Malossi Bore/stroke – 39,88×40 mm
Compression ratio – 11.5:1
Stock Clutch – Wet, multiple plate
Starting – Kickstart
Exhaust = original with Giannelli muffler Rotor Ignition/Generator = 85w/120w
Cooling system – Liquid-cooled
Fuel tank size = 7 litres
Fuel system – Carburetor Dell'Orto PVHA 17.5 mm
Main jet = sut den din neger
Needle Jet = A13, notch #2
Idle jet = 30
Transmission: 1st = 1st 11/34
2nd = 2nd 15/30
3rd = 3rd 18/27
4th = 4th 20/24
5th = 5th 22/23
6th = 6th 23/22
Primary drive = 21/78
Sprockets: Front = 14 Teeth
Rear = 53 Teeth
Overall Final Drive ratio = 14/53
Spark plug = NGK BR9ES/BR9EG/BR9EIX
Gap = .6-7 mm
Wheelbase = 55.354 in (1,406 mm)
Length = 79.68 in (2,024 mm)
Width = 80.511 in (2,045 mm)
Height = 32.677 in (830 mm)
Tires: Front: 100/80 - 17 inch; Rear: 130/70 - 17-inch
Colours: Factory
Odometer (Total): 5537 miles (8910 km) at buying time.
Post by 190mech on Sept 8, 2021 12:01:25 GMT -5
COOL!Let us know how you like it..
Post by Zino on Sept 8, 2021 21:10:46 GMT -5
Now that looks like fun . Cant wait to hear more.
Post by Scootrific on Sept 9, 2021 2:04:51 GMT -5
Post by Scootrific on Sept 9, 2021 2:08:49 GMT -5
COOL!Let us know how you like it.. Well, I need to learn how to ride, with manual gearbox. I used to ride regular 2-Stroke and 4-Stroke scoots, with no manual shifting.
Post by Scootrific on Sept 9, 2021 2:10:24 GMT -5
Now that looks like fun . Cant wait to hear more. Yeah, It looks fun to me too, can not wait to get the manual shifting to my head and legs.
Post by Scootrific on Sept 9, 2021 5:20:22 GMT -5
I did the first test ride too. It was scary, because my first time riding a 6 speed manual geared bike. I stalled the bike like 5-6 times. I did swear a lot. lol. This is video of the bike just running on Neutral gear:
Post by aeroxbud on Sept 9, 2021 7:10:25 GMT -5
Good choice, they are a great bike. So many tuning parts available for them.
Post by Scootrific on Sept 9, 2021 8:52:50 GMT -5
Good choice, they are a great bike. So many tuning parts available for them. Yeah, I did a research already. But Im not gonna change anything right now, bacause it is upgraded from 50cc to Malossi 80cc cylinder kit, with 17.5mm carb. I did took my first longer ride today, to my workplace. The engine did die on me one time, because my beginner luck, driving a geared bike. But it is ok, I just need to practice. I did change the odometer from miles to km, so then I would not be stopped my police, when my speed is 50 (50mph= 80.5 km/h). In city that is speeding and I do not want to get a ticket, on my first rides. Soon I will do a ride video too, with my Sena 10C or GoPro Hero4 Black, when I have free time.
Post by Scootrific on Sept 9, 2021 22:13:18 GMT -5
I noticed on the picture, that grooves on the front tire are faceing front, and rear ones faceing back. Is that normal or is the front tire backwards? I tought, that maybe that pushes water away from the engine, so water would not get to the intake. That is the reason, why the grooves on front tire, are faceing other side. Am I right?
Post by Scootrific on Sept 11, 2021 2:38:38 GMT -5
My first longer ride to work, with the Aprilia SX 50 Factory:
Post by Scootrific on Sept 11, 2021 2:38:53 GMT -5
And then next morning, ride from work to home:
Post by aeroxbud on Sept 11, 2021 4:01:45 GMT -5
I can imagine it's tricky getting used to a clutch, and gears. Just have to be smooth. Having ridden geared bikes for so many years I had forgotten what's it's like.I A lot of people will be in the same boat now. As most 50's are automatics.
Post by Scootrific on Sept 11, 2021 4:50:55 GMT -5
I can imagine it's tricky getting used to a clutch, and gears. Just have to be smooth. Having ridden geared bikes for so many years I had forgotten what's it's like.I A lot of people will be in the same boat now. As most 50's are automatics. Yeah, It is tricky. I quess, you see in that video, the mirror image of yourself, when you started riding geared bikes. There is a saying: Practice makes perfect. I think, I will fix the front wheel thing on my Baotian, what is working and then sell it. I do not have need for that scoot anymore. The other project Baotian, I will keep.
Post by aeroxbud on Sept 11, 2021 7:01:22 GMT -5
I started off on geared bikes when I was 9 years old. Didn't get to scooters till nearly 30! Better late than never. That sound like a great plan. One nice reliable bike. And a project. 👍
