Post by Scootrific on Sept 30, 2021 12:46:44 GMT -5
Most of the ordered stuff, what came from Germany were inside the package, exept one thing. It was not available: Chain AFAM XS-Ring reinforced gold 428 XMR-G 146 linksI contacted the Scooter-Attack Crew. I did infrom them, that I do not need that chain, because I found 420 chain from D.I.D, in my country. I quess, I could not use the 428 chain on my bike, but I could be wrong. I even checked the rear sprocket on my bike. It has 53 teeth sprocket, but Im not sure, the size of the front one. That could be with 11 teeth.
Post by Scootrific on Sept 30, 2021 12:48:22 GMT -5
Post by Scootrific on Sept 30, 2021 12:50:26 GMT -5
And picture from my home. One heavy weight and one lighter one together:
Post by Scootrific on Nov 2, 2021 23:44:10 GMT -5
Yesterday, I was riding from home to work and this happened. Deam, Im glad, that my Aprilia SX50 has so good brakes.
The emergency braking on my Aprilia SX50. (Orange Stage to Red Stage, maybe little bit Brown Stage too). Shorts were clean of Brown Stage.
Post by aeroxbud on Nov 3, 2021 6:31:59 GMT -5
That's pretty normal for here. You have to keep your wits about you.
Post by Lucass2T on Nov 3, 2021 10:04:33 GMT -5
The emergency braking on my Aprilia SX50. (Orange Stage to Red Stage, maybe little bit Brown Stage too). Shorts were clean of Brown Stage. I see you're watching dandanthefireman too
Post by Scootrific on Nov 3, 2021 18:07:04 GMT -5
I see you're watching dandanthefireman too Yes I do watch him. Poo-Poo in the batalones (Brown Stage)
Post by Scootrific on Jan 11, 2022 12:45:24 GMT -5
Post by aeroxbud on Jan 12, 2022 7:06:45 GMT -5
There is a knack to using those, easy once you have done it a few times. If you put the side stand down, and a small piece of wood under it. You can steady the bike with one hand, and raise it with the other. It's a good idea to leave the stand down. If it goes to fall when lowering. You can catch it on the stand.
Post by Scootrific on Jan 12, 2022 13:12:12 GMT -5
There is a knack to using those, easy once you have done it a few times. If you put the side stand down, and a small piece of wood under it. You can steady the bike with one hand, and raise it with the other. It's a good idea to leave the stand down. If it goes to fall when lowering. You can catch it on the stand. Good to know, but the side stand is spring loaded, fro safety, so the stand will not be forgotten, when rider starts to ride.
Post by aeroxbud on Jan 12, 2022 15:27:39 GMT -5
It will still stay out on its own. It's on a pivot, so has to go past a certain point to spring up.
Post by Scootrific on Jan 13, 2022 0:53:39 GMT -5
It will still stay out on its own. It's on a pivot, so has to go past a certain point to spring up. I will check it, but I think it will not say on his place.
Post by Scootrific on Mar 14, 2022 13:34:21 GMT -5
Something came to visit me in the garage and wanted some spring love. It was my 2020 Aprilia SX50 Factory. I cleaned and oiled the chain. Also I checked, it she starts or not. She did.
Post by Scootrific on Mar 18, 2022 13:01:30 GMT -5
I brought a new battery for the Aprilia SX50 Factory (just in case), because the dealer who did sell me the used supermoto, recommended to buy a new battery some time in near future. I also did buy new battery for the QT-9D, what had front wheel bearings shot. I noticed, that the battery is also shot. The white battery is for Aprilia and black AGM is for QT-9
Post by Scootrific on Mar 22, 2022 0:37:08 GMT -5
Last time in garage, I did took the old YUASA YB4L-B battery out of the Aprilia SX50 and replaced with a new one. After that I did ride to work and next morning back to home. Weather was beautiful, the awesome sky at evening .... Mmmmmm.
