Post by sToRm on Sept 15, 2021 16:43:58 GMT -5
I have a 150cc GY6 Long case engine and need to replace the cylinder head. Engine code is BN157QMJ. The CVT cover has Wolf stamped on it. Old cylinder head needed a block off plate. Can anyone suggest a suitable replacement?
Post by scooter7878 on Sept 16, 2021 4:27:36 GMT -5
*********Shit sry didn't see u have a 150cc scratch scooter to go but unique and parts galore def have some nice looking stuff for the 150cc either way go with a big valve set up it for sure adds a good amount of power ********* I run a stroker with a airsal 50mm kit and one of the older bvh with 23/20 mm valves. It's a cheap head from Amazon I think either glixal or goosfit but it was 30 bucks and TBH it works fine I did have to port it a little and after about 2500 miles I had slight leakage from the valves which I relapped and it's been working fine. That being said if I had my choice I'd run the naraku bvh I think ssp-g makes a good bvh also. If ur looking for a cheaper option scooters to go has a bvh for around 40 which is supposed to pair well with the airsal piston he has a cylinder with airsal piston and head for around 90 bucks I believe. His head has a smaller dish cut out which helps keep compression up and bibber than stock valves but smaller than the older style bvh I believe his valves are something like 18 and 20mm. My next buy is either a naraku 52mm cylinder and head or I've seen on eBay u think either parts galore or unique has some tiwan cylinders and heads which look very well made u may go that route. But all and all the head I got from Amazon has probably around 7500 miles on it now and still going strong. And I can say I have swapped from my bvh to a big bore head that came with a bbk kit and the bvh definitely adds a lot of power,top speed and revs up way faster.
Post by sToRm on Sept 17, 2021 10:14:09 GMT -5
Thanks for the info.
