loosegrit
Too much work. Hope for another scooter run Oct 2015.
Post by loosegrit on Nov 11, 2011 20:43:09 GMT -5
Handy Carrier Take your almost useless lock box and turn it into a handle carrier. Remove the door. Cutoff appox. 2-1/2" ( I'm sure you can cut straighter than me. ) Reinstall the bottom part. Use two small screws to secure top. You will be surprised, how handle this is.
Post by 90GTVert on Nov 11, 2011 21:18:45 GMT -5
That is an interesting idea, and not something I woulda thought of.
Post by Fox on Nov 11, 2011 22:48:59 GMT -5
I like it! I rode a scoot like that for a few years and I never used that compartment hardly ever cause everything falls out when you open the door.
Great job! :thumb:
Post by stepthrutuner on Nov 12, 2011 11:03:11 GMT -5
I like it! I rode a scoot like that for a few years and I never used that compartment hardly ever cause everything falls out when you open the door. Great job! Here's an answer to that. The spring was a little heavier than I wanted but it was all I could find laying around. I had to stretch it out til it's tension suited me. I did have a tiny fabric covered bungee here but it frayed away. Pop rivets hold it in place. The center rib of the glove compartment is recessed enough to allow the door to close. Those are my clear night riding eye protection on the left and my 12v air compressor on the right.
Post by Fox on Nov 12, 2011 13:56:09 GMT -5
Yeah that helps. I saw another guy put a piece of netting across there to keep everything from falling out when you opened the door. I kept my registration papers in there.
Post by stepthrutuner on Nov 12, 2011 14:25:21 GMT -5
Please note the section of clothes hanger employed as the glove box door hinge pin.
Post by 2strokd on Nov 14, 2011 3:30:17 GMT -5
Thats cool! Now im thinking of putting that door back on the Cobra.? Only if its cut tho! Mine never shut all the way anyhow.
Post by Fox on Nov 14, 2011 20:19:20 GMT -5
I'm thinking a metal bracket running on the inside an inch below the top would be better to screw into so the screws go in straight. It would be stronger that way too. you screw the bracket into the sides of the compartment as shown in my crude diagram below. Then you screw through the door into the metal.
loosegrit
Post by loosegrit on Nov 14, 2011 20:22:24 GMT -5
I will give it a try. Thanks
Post by docxen on Apr 3, 2014 11:39:40 GMT -5
neat idea any ideas for a cheap drink holder? thinking maybe a large plastic cup with strong magnets
Post by 90GTVert on Apr 3, 2014 12:12:05 GMT -5
If you just want to carry drinks one simple thing I've seen is thick foam cut to fit under the seat snug with a couple of holes for drinks. Holes are made a little small so it squeezes the drinks. Foam has to be a few inches thick. If you want a cup holder that can do open beverages you need one on a swivel or it'll spill when you lean. www.google.com/search?tbm=isch&as_q=swivel+cup+holder
