Post by Deleted on Oct 19, 2021 18:51:32 GMT -5
Hi dear members!
I have issues with the battery charging system of my 2005 Yamaha Zuma that I recently acquired in used condition.
How can I figure out which part is the problem? In what order should I check things and what can I exclude as possible reasons?
Backstory:
When I first got the scooter (about a month ago) the battery was working alright. Pretty quickly after though it would not be strong enough anymore to start the scooter, so I had to start using the kick starter. This worked fine for a while until I noticed the lights dimming and completely turning off and also the blinkers not working anymore. I assumed the battery was probably old and got a new one.
Worked fine for about two weeks now (I usually drive 2-5 miles distances few times a day and sometimes longer ones) but now the scooter stopped again to start electronically with the switch and I have to use the kick starter again. At the moment the lights and blinkers are still working as soon as the engine is running.
This time, because the battery was new, I assumed that the issue is with the charging system. So I got a volt meter and measured the DC voltage of the battery and these where the results:
turned off ~ 11V
idle ~ 11V
revving ~ 5-6V
I'm definitely no expert, but after researching a bit I understand that revving the voltage should be at about 14V and idle should be at about 12V (I assume this is lower bc it has not been properly charged).
From here I tried to make some research about what could be the reason and my next step was to test the voltage output of the stator. Here is where I am am kind of stuck, because the three cables coming from the cable of the stator towards the CDI are not clearly color coded (black, white, and red/yellow striped). In the video I found (https://www.youtube.com/watch?v=AZbg-krvZM4), it was said that the voltage should be around 25-35V with an idle engine, but what I measured on my scooter was about at 12-14V (if I measured right).
Now I am unsure whether this tells me that my stator is not generating enough voltage to charge the battery and I need to change it or whether I should take other steps first?
Every help is very much appreciated!
Backstory:
turned off ~ 11V
idle ~ 11V
revving ~ 5-6V
