fmont
Scoot Newb
Post by fmont on Nov 3, 2021 3:08:45 GMT -5
Hey all. Not so much new as returned. I was real active/mod at Zumaforums way back. Ready to change things up again with my scoot and talk tuning.
I'm a bugeye guy. I've got an 08 that's pretty well worked over. S6 Racing mk1 (Athena Evo) cylinder is still going strong after many, many years (and proper maintenance). Run either a C16 or Athena "Sporting," which is what the S6 PRO was. Right now it's got the C16 on it. 21mm Dell Racing PHBG. The non-flashy Malossi overrange, delta clutch, Doppler 15/50s for 11:1 final drive, Aerox 100 wheels with IRC MB99 tires, S6 forks with S6 big brake, naked bars, fully LED converted, etc. Runs mid 60's mph comfortably. Best top is 67mph GPS, I'm not ported and still run standard ignition, though. Changing that and a lot more this winter. 😁
Some of the ZF names I remember are Pig, Corrosion, Moofus, Specalk, Spaz, Goshi, I'll just say Nick B in case he doesn't want his name posted, and so on. Not sure who's still active out of that crew, but hopefully some of you are still around. I think I went by Fmont back then, too. I can't even remember! 😂 Getting old I guess.
Cheers.
Post by aeroxbud on Nov 3, 2021 7:28:03 GMT -5
Welcome to the forum. That sounds like a nice build. You should start a thread in the build section.
messenger
Post by messenger on Nov 3, 2021 9:49:06 GMT -5
welcome to the forum
I run the same cylinder, pipe and carb as you, but ive got a piaggio motor in a Gilera Runner.
Post by fly on Nov 4, 2021 7:02:12 GMT -5
oop, here's my old profile lol.
Post by 90GTVert on Nov 4, 2021 9:30:29 GMT -5
Welcome / welcome back! Some of the names you mentioned are still sort of around. I saw that you found PIG's thread. He doesn't post much these days. Same for moofus02 Corrosion and spaz12 unfortunately. Most of them have at least popped back in at some point or said hello somewhere.
Post by 65grendel on Nov 5, 2021 4:58:20 GMT -5
Welcome I would love to see some me pics of your scoot
Post by fly on Nov 6, 2021 4:43:26 GMT -5
Welcome I would love to see some me pics of your scoot Will do ASAP friend-o.
