kevino
https://www.youtube.com/watch?v=04dSGwAssRA
BBK?
Nov 14, 2021 16:28:23 GMT -5
Post by kevino on Nov 14, 2021 16:28:23 GMT -5
I see all sorts of kits for sale on Amazon. As I understand it, 80cc cylinder kits can be installed by simply replacing the 50cc jug and piston. But what about 100cc kits? I assume they need cutting into the block, different crankshaft, camshaft and rod? At what point is it better to buy a bigger engine?
TIA,
kevino
BBK?
Nov 15, 2021 1:23:18 GMT -5
Post by FrankenMech on Nov 15, 2021 1:23:18 GMT -5
Check out the forum section for BBK.
BBK?
Nov 15, 2021 6:44:30 GMT -5
Post by aeroxbud on Nov 15, 2021 6:44:30 GMT -5
I think a lot of the 100cc kits are only 81-88cc. Check the bore size. 47mm=72cc, 50mm=81cc, and a 52mm=88cc. It's hard to put a 150 engine into a 50cc. It has very different mounting points.
kevino
BBK?
Nov 17, 2021 11:11:51 GMT -5
Post by kevino on Nov 17, 2021 11:11:51 GMT -5
THANKS,
