Post by scooter7878 on Nov 29, 2021 20:43:45 GMT -5
These are all trusted shops on eBay that have tadia and other good parts. As for the pump I've seen the vacuum pump ur talking about I'd have to look into exactly how it works and weather it's needed. U believe if u set it up with bigger fuel hose and a manual petcock And had the hose routed so it gravity feed well it would be good the carbs don't need pressure to work just enough fuel the oko flat slide has a big feed nipple so bigger hose and a downward running gravity feed I would think is fine if it was me I'd run bigger hose a manual petcock and the 32mm oko flat slide and if I was having fuel supply issues when at wot for long periods of time I'd look into electric pump. If u were having a fuel supply issue it would only be when u were running wit for long periods and the carb bowl was not filling fast enough but with 1/4 or 5/16 hose and downward running if hose so it feeds well I pretty sure it's enough a 1/4 inch hose flows a lot of gas if you let it flow it should be plenty as carbs don't need pressure just enough fuel to keep bowl full
Post by scooter7878 on Nov 29, 2021 20:53:50 GMT -5
Thinking about it the only rocketa I worked on the tank was mounted below the carburetor so that would make sense why it's a vacuum pump not just a petcock if ur tank is below the carb u will def need a low pressure pump to feed the carb
Post by alyster on Dec 1, 2021 23:18:17 GMT -5
Thinking about it the only rocketa I worked on the tank was mounted below the carburetor so that would make sense why it's a vacuum pump not just a petcock if ur tank is below the carb u will def need a low pressure pump to feed the carb Sorry I'm a chef and have been busy. But the intake on the carb has a line already tapped into it so could I possibly just run the vacuum line for the "pump"to that?
Post by scooter7878 on Dec 2, 2021 3:52:07 GMT -5
Yes if ur gonna run the vacuum pump u can use that port on the manifold
Post by fugaziiv on Jan 25, 2022 10:29:04 GMT -5
These are coming into stock sometime late spring. I don't know what the final price will be yet, but I do know it'll most likely go up a couple hundred bucks because that's the world we live in now. Matt
