Post by chadbullet on Dec 21, 2021 20:33:58 GMT -5
I was lacking motivation on this build, but the ball has been rolling on it lately. Horizontal Minarelli from YW50 Stage6 Racing MK2 70cc cylinder Doppler Endurance crank SCR Corse Handmade 70 pipe 2TR intake (subject to change) Polini CP24 Evo or PWK 24 Malossi LFR Overrange Stage6 torque control clutch Stage6 R/T clutch bell Doppler 14/42 primary gears The crank went in this past weekend. The threads on this Doppler crank were horrendous. It doesn't inspire too much confidence in it's overall quality. I ran out to Harbor Freight for a $20 tap and die kit. It's already earned it's value to me. I used it to clear crud out of the engine stud holes as well. I cut the handles down on the tool so it'd fit inside the case. The shorter arms are more than enough leverage anyways. I wanted to remove the abysmal passenger hump from this seat. While at it, I thought it'd look cool to trim the seat down anyways. I'm really liking the lower profile. We'll see how it feels on longer rides. And here's where we're at today. I'm waiting on the correct piston. Somehow I ended up with 10mm wrist pin piston, but the correct 12mm pin and circlips came in the 12mm labeled box. hmmm... While waiting I mounted everything up so I can start working on the wiring harness.
Post by chadbullet on Dec 21, 2021 20:48:13 GMT -5
This is how it looked when I first purchased it. This was my 2nd scooter ever, so I hadn't quite bitten the bullet and jumped into modifying scooters. After months of ownership and really enjoying the bike, it was stolen from my apartment. Over a month passed and while getting gas for my car, I saw my scooter going down the road. I got in my car and followed until it was eventually abandoned. It was rough. The tweekers messed a lot of stuff up. Fortunately they didn't get into the wiring. While this scooter was missing, I had replaced it with a twin. Now having 2 prebugs in my fleet, I decided I could tinker with the theft recovery. It got a Polini Corsa and a Yasuni C16. This is how it was until earlier this year when I decided to build a horizontal. The corsa was swapped into the other prebug.
Post by chadbullet on Dec 21, 2021 20:50:53 GMT -5
I had a donor bike. It was going to require a bit of elbow grease to clean up before sending it to MvS.
Post by chadbullet on Dec 21, 2021 21:04:25 GMT -5
Post by chadbullet on Dec 30, 2021 17:48:20 GMT -5
New rear tire arrived. I decided to give the Kenda K764 a try. It's hard to find 130/90-10 in higher than J rated, and this is M rated. Rubber feels soft to the touch. I'm looking forward to seeing how it does. I also decided to run a front wheel from a Kymco Agility. It's a 12" wheel which will be better for tire options. There is a negligible difference in diameter between 120/70-12 and the stock 120/90-10. And it is ready for 12mm axle which will match the NCY legs I'm using on the bike without having to use shims. It also didn't hurt that it was $80 shipped in great condition. edit: oh! and that they fit the more common rotor size. Otherwise would likely have kept original front wheel.
Post by Lucass2T on Dec 31, 2021 4:07:47 GMT -5
Thats one super clean porting and trenching job! Nice!
Post by chadbullet on Dec 31, 2021 5:58:32 GMT -5
Thats one super clean porting and trenching job! Nice! That's why I paid a professional! haha Anything that requires a steady hand isn't really a task for me.
Post by hellish100 on Dec 31, 2021 10:12:51 GMT -5
Nice engine build! Can you share more about the engine mount?
Post by chadbullet on Dec 31, 2021 14:58:32 GMT -5
Post by aeroxbud on Dec 31, 2021 16:06:24 GMT -5
Going to be a nice bike when finished. I have seen a couple of swapped vertical Minarelli to horizontal before. Is always an interesting build.👌
Post by chadbullet on Jan 2, 2022 17:00:33 GMT -5
I've been putting off the electrical side of things for a bit, but today was a step in the right direction. The original coil location could have worked, but it would have required a really long spark plug wire since the top of the cylinder has moved a bit further away. This spot seems nice though! I decided to put the CDI nearby as well. I ran a long bolt through the battery box so I'd have somewhere to attach it to. Then I used a couple of rubber grommets and a small piece of foam weather-stripping to dampen it. Now that everything electrical is in place. I don't have any excuse for why I can't start running wires.
Post by chadbullet on Jan 3, 2022 21:27:19 GMT -5
Post by chadbullet on Jan 5, 2022 8:46:38 GMT -5
Post by chadbullet on Jan 6, 2022 8:33:00 GMT -5
Leakdown test. I saw that some people just oil their base gaskets so I tried that in lieu of Hondabond. Well, the only spot leaking is front the base gasket, so I'll pull it apart this evening and retry with sealant instead of oil. No noticeable leaks from any of the seals, head gasket, or intake, so that's good!
Post by Lucass2T on Jan 6, 2022 10:36:34 GMT -5
I use silicone sealant on everything (except o-rings, oil seals and exhaust) downstream of the carburettor. Intake, reeds, cases, base gasket. Some say it's unnessecary but a very thin film never hurt nobody.
