Post by Misfit J on Jan 2, 2022 13:41:13 GMT -5
What's up all. I'm Jacob and some what new to the fourm. I have spent countless hours researching this and other fourms for info. I own a 2021 db50qt-2a with a 1p39qmb engine. I have learned sooooooooooooooo much from the people here and other sites about the scoot. I have all ways been a gear head and love working and mixing things. So here's what's going on so far... The build list.. 72cc bbk with ported head and 64mm valves- gy6racing Ssp-g performance camshaft - ncy 20mm carb with 88 main jet and 34 pilot jet - amazon 38mm pod filter- amazon Performance exhaust- amazon Upgraded intake manifold with one vac port - gy6racing Gravity feed fuel system - local hard ware store 89mm variator 5gram dr.pully sliders- ncy Light weight clutch bell- ncy 1000rpm clutch springs - ncy 1000rpm torque spring - ncy Adjustable secondary sheave - ncy Kevlar 699 18 30 belt Complete upgrade ignition system, blue cdi, orange coil and wire - amazon Ngk iridium spark plug - local auto parts store Various roller weights to tune with currently running 3 9 gram rollers to get 4.5 gram setup. Short led light bar up front - walmart Aftermarket turn signals with with blue running lights - amazon Simple led gauge cluster just speed and tach - amazon Chrome air scoop - amazon. These things are great. Love wrenching and modding
Post by aeroxbud on Jan 2, 2022 14:08:20 GMT -5
Welcome to the forum Jacob. That's quite a list, you should start a build thread. I would try and limit how many changes you make at one time. It's much easier then to get an idea of how well they work. And troubleshoot problems.
messenger
Post by messenger on Jan 2, 2022 15:36:05 GMT -5
Welcome
Post by 90GTVert on Jan 2, 2022 15:51:59 GMT -5
Welcome to 49ccScoot!
