565
Scoot Junior
Post by 565 on Feb 10, 2022 10:05:06 GMT -5
my gy6 80cc weighs 110 kg and its top speed is around 65-70 km / h. There are bigger nozzles installed. Is that normal or should there be a higher speed?
br4inl3ss
Post by br4inl3ss on Feb 12, 2022 20:06:55 GMT -5
im not a good source of info at all. but to what i read and see, you should easily get over 70. a friend of mine living in the us ( im from canada ) have a taotao and with his 81cc bbk he can fly up to 85 km/h. i think you have way too much acceleration thus why you have this speed. try lighter rollers.
Post by steve1297 on Feb 13, 2022 8:42:19 GMT -5
About 70-75km/h Is normal.
If that guy is going 85km/h on an 80cc, without up gearing, I'd like to see GPS proof. I've got a Naraku 52.4mm piston and stroker crank, making mine 94cc, and with stock gears I top out at 85km/h absolute tops.
br4inl3ss
Post by br4inl3ss on Feb 13, 2022 14:17:54 GMT -5
About 70-75km/h Is normal. If that guy is going 85km/h on an 80cc, without up gearing, I'd like to see GPS proof. I've got a Naraku 52.4mm piston and stroker crank, making mine 94cc, and with stock gears I top out at 85km/h absolute tops. yes been confirmed with gps and compared to cars going the same speed. he probably has gears. all i know is he hit that speed easily , and the ONLY mod he did to the ENGINE is his 81cc bbk ( i dont know if he bored the case , thats why im asking if i'll need to ). no exhaust , no huge carb ( 18.5 racing naraku the same i just put on mine ) , no useless cone filter , nothing. he didnt talk about transmission tho. so yeah he probably has gears. but honenstly i guess something is wrong on yours. mine is STOCK right now , not even a bigger jet , and i hit 60 in a respectable time. its def not ultra fast , but decent. to compare, since you have alot of taotao in the us , mine is clearly faster than a stock taotao atm50. everyone else i see runs 72cc and can hit 75 ( but similar acceleration as sock ) so something not setup right , there.
Post by steve1297 on Feb 13, 2022 22:15:44 GMT -5
You don't need to cut the case. It all depends on the gear ratio the scooter came with. Scooters with 10" wheels come with a longer gear, and can Normally hit higher speeds than scoots with 12" wheels. If you have 12" wheels, either order new gears, or take some out of a 10" scoot
Post by 90GTVert on Mar 12, 2022 10:23:22 GMT -5
~70km/h is pretty standard for a 47mm BBK. You may find that CVT tuning will help. It may be able to go faster with heavier weights, but that could have an adverse effect on acceleration.
Post by 2strokemafia on Apr 28, 2024 21:00:53 GMT -5
Post by 2strokemafia on Apr 28, 2024 21:01:26 GMT -5
Post by 2strokemafia on Apr 28, 2024 21:06:48 GMT -5
Idk I have a 06 Derbi Atlantis 50CC AC with a Leo Vince pipe and 3 4.5 gram weights and 3 stock weights and I hit mid 80kph Consistently I've got over 20 thousand kilometers of GPS logs that says true and my best drafting behind a truck in full tuck I hit 92 KPH. So I'd say if your 80cc is hitting only those numbers you have some issues somewhere brother. Cheers
br4inl3ss
Post by br4inl3ss on Apr 29, 2024 9:02:14 GMT -5
but this is a 2 stroke fly..... 2broke runs at way higher rpm. the scooter i have now is hitting 65 gps bone stock and 68-69 on very long road no incline no wind. but this was with terrible stock pulley and clutch and variator. at 9300 rpm. 9300 rpm is like nowhere near what most 2broke runs at. so right there we have a huge speed difference.
and iirc they're not geared the same.
