Post by dahermit on Apr 3, 2022 19:09:12 GMT -5
I need to remove my Tao Tao Future Champion CY50A VIP 50 Speedometer and Front Handlebar Panels. I have removed every screw apparent on the outside that could be holding them on, but for the life of me, cannot find why they will not come loose. I have looked for any YouTube Videos that would help to no avail. Can someone one give me any help with this problem? Speedometer PanelFront Handlebar Cover Panel
claydoh
Post by claydoh on Apr 4, 2022 5:30:36 GMT -5
If I recall correctly, the two pieces are clipped together along the top edge quite tightly. You may need to gently pry them apart, starting on one side. Note the speedo cover's third image - see the two loops and the tab in the center.
I don't have minbe any longer (stolen) else I'd shoot a quick video.
The two pieces also take a bit if force to snap back together.
Post by dahermit on Jun 3, 2022 19:57:04 GMT -5
Addendum: In as much as the front handle bar cover is broken and going to be removed anyway, I figured that if I ordered a new one I could examine it and figure out what is still holding it on (I remove all the external visible screws and bolts connecting it to the scooter that were not already missing (most of them already gone via previous owner(s))). The front handle bar cover came today and it appears that there are two mounting screws that are only accessible when the speedometer cover is removed. I have called them out with solid Red arrows in the attached photo. However, the plot thickens in that the speedometer cover also has all the externally visible srews and bolts removed and it seems still stuck on the scooter. Or in other words, I need to get the speedometer cover off to get at the screws that are holding the front cover on. Any persons who have a 2014 or so VIP Future Champion or anyone who has taken the speedometer cover off one of those... can you give me some help here?
claydoh
Post by claydoh on Jun 3, 2022 23:55:47 GMT -5
I've..ahem.. borrowed.. an image from HERE
Note the two round tabs at the top left and right, plus the square one in the middle. These snap over respective notches on the front cover. Or, rather, the front cover snaps into these tabs.
And the rest of the top edge fits quite tightly into the grooves formed by the remaining tabs you see on your image .
It really is very tightly fit, but you do have to sort of pop those three tabs down, and away, to separate the pieces. There really are only those 4 screws/bolts holding the speedo covers together, besides the strong connections on the top lip.
I am mostly working from memory, tbh. The 5 posts on the interior iirc is not only where the speedo mounts, but also where both attach to the handlebars.
Post by dahermit on Jun 4, 2022 7:13:12 GMT -5
claydoh
Post by claydoh on Jun 4, 2022 10:16:36 GMT -5
Those three posts are what the actual speedo bolts to, both the speedo and the speedo panel bolt to the handlebars via these posts.
you undo the two screws that are near the controls (facing the driver), and the two bolts on the sides, under the brake lever area, and then you have to sort of pry, wiggle, cajole the front cover up to separate the front and rear covers, while also possible pushing down or prying the areas with those loop tabs. The rear does not come off until the front has been removed as it is screwed to the handlebar.
It will be much clearer when you see the two halves together.
Post by dahermit on Jun 4, 2022 15:42:13 GMT -5
Addendum: I did get the speedometer panel to pop free with a snapping sound. However, looking at it, I could not for the life of me see what had been holding it on.
Aside from that, the Speedometer panel definitely needs to be removed to access the screws that go through the metal tabs on the handle bars.
So, at this point, progress has been made. I do not anticipate any serious problem re-mounting the new front panel and the new speedometer panel when it gets here.
