Post by ghostaroni on May 1, 2022 12:45:50 GMT -5
Parts List
¤70CC DR Evolution Racing Cylinder
¤Full Circle Crank Top Performance
¤Yasuni R exhaust
¤Top Performance Variator (4.5gram sliders)
¤Malossi MHR Clutch and Bell
¤CP21 carb (30° slide, 14/22 needle, 40pilot, 112 main)
¤s23 intake manifold
¤Yamaha stator and ignition
¤Malossi CDI
¤s23 FiberGlass reeds
¤Malossi Crank Seals
Top Speed as of now 55mph, With room to go. (i have an airleak(wasnt an airleak; turned out to be a leak by the exhaust silencer whistling) and need to change to a bigger intake manifold, Then I need to change my throttle slide from 30° to 40°)
pili
Post by pili on May 1, 2022 13:48:11 GMT -5
Sounds good. Responsive.
Post by ghostaroni on May 2, 2022 23:30:47 GMT -5
Its a dog I think I need to upgear lmao
Post by Zino on May 3, 2022 7:07:05 GMT -5
Go For it The Gears would push you over 60 mph .
Gears were my cheapest Top speed addon I just had to drop weights a notch so I had the same shift points in the transmission
Post by ghostaroni on May 3, 2022 22:21:14 GMT -5
Go For it The Gears would push you over 60 mph . Gears were my cheapest Top speed addon I just had to drop weights a notch so I had the same shift points in the transmission I was gunna go up on slider weights; Thank you for saving me time and stress. Im at 4.5 gram sliders rn and I will definitely upgear. Then im going straight to the speed list. boo yah
Post by ghostaroni on May 3, 2022 23:25:00 GMT -5
Post by ghostaroni on May 18, 2022 21:51:52 GMT -5
Update: A broken piston pin clip has destroyed the poor cylinder... Shame too, Cylinder was breaking in nicely. I'll be back!
Post by repherence2 on May 18, 2022 23:09:20 GMT -5
get a cylinder head temperature gauge too.
i giggled when i read "cylinder was breaking in". i giggled because i am from the opposite end of spectrum when it comes to "breaking in" bore kits. i used to do break in cycles because that is what i read about on the internet forums. one day, i asked a mechanic/tuner about his break in process and he said, "I do a hard break in to seat the rings." it just made so much sense to me that ever since then, now i only do hard break ins. my coworker who rode a Yamaha street bike is also a firm believer in the hard break in to seat the rings, he did a hard break in when his street bike was brand new from the dealership. to me, it just makes so much more sense; if im setting up an engine to be able to go WOT for long duration as a daily rider, i might as well seat the rings at full RPM from the get go. to each, their own.
but a CHT gauge just makes tuning the carb so much easier. it also helps prevent soft seizes and/or burning holes in your piston. it takes the guess work and plug reading out of carb tuning/jetting. i just tune for 350*F at wide open throttle. that is how i set my main jet and that is when i break it in. once i find a main jet that can keep me at 350*F WOT, it becomes the break in phase. once i find the main jet that keeps me at that temperature, it is balls to walls holding WOT for long distances. 350*F is a "safe" region and it provides for reliability as well. you can easily tune to the hotter/leaner side of 400*F if you know what you are doing and you understand the Edge of reliability and unreliability. the Honda guys with Polini Corsa bores have gone over 400*F.
all i am saying is this, get a CHT gauge and tune to your heart's content. at least you can monitor (somewhat real-time) what is going on with your engine (fueling). fueling = cooling. cooling = reliability/longevity.
--do you happen to recall the orientation of the the clip when you installed it? as in, was it positioned like and "m" or like a "c" or "E".
Post by ghostaroni on May 19, 2022 3:08:59 GMT -5
get a cylinder head temperature gauge too. i giggled when i read "cylinder was breaking in". i giggled because i am from the opposite end of spectrum when it comes to "breaking in" bore kits. i used to do break in cycles because that is what i read about on the internet forums. one day, i asked a mechanic/tuner about his break in process and he said, "I do a hard break in to seat the rings." it just made so much sense to me that ever since then, now i only do hard break ins. my coworker who rode a Yamaha street bike is also a firm believer in the hard break in to seat the rings, he did a hard break in when his street bike was brand new from the dealership. to me, it just makes so much more sense; if im setting up an engine to be able to go WOT for long duration as a daily rider, i might as well seat the rings at full RPM from the get go. to each, their own. but a CHT gauge just makes tuning the carb so much easier. it also helps prevent soft seizes and/or burning holes in your piston. it takes the guess work and plug reading out of carb tuning/jetting. i just tune for 350*F at wide open throttle. that is how i set my main jet and that is when i break it in. once i find a main jet that can keep me at 350*F WOT, it becomes the break in phase. once i find the main jet that keeps me at that temperature, it is balls to walls holding WOT for long distances. 350*F is a "safe" region and it provides for reliability as well. you can easily tune to the hotter/leaner side of 400*F if you know what you are doing and you understand the Edge of reliability and unreliability. the Honda guys with Polini Corsa bores have gone over 400*F. all i am saying is this, get a CHT gauge and tune to your heart's content. at least you can monitor (somewhat real-time) what is going on with your engine (fueling). fueling = cooling. cooling = reliability/longevity. --do you happen to recall the orientation of the the clip when you installed it? as in, was it positioned like and "m" or like a "c" or "E". rest assured I made sure to beat on this one within reason from the get. I have learned that the best way to break in an engine is to beat it, but not like it owes me money. full throttle for 3 seconds, winds down, full throttle 3 seconds, wind down, etcetc. I do that for 5 minutes then I turn the engine off to let it cool, then its beating from there. I will reinstall my temp gauge, And eventually get a non cheap one.(I use the temp gauge as a tuning tool only cause I think they look goofy. I was hitting about 340°f WOT. I had the C part facing upwards, If that matters.
Post by Zino on May 19, 2022 7:56:25 GMT -5
C up or down is better than side ways . I mounted my trail tech temp gauge on the vino's right under the speedometer. I zipped tied it tight it looks like it belongs there .
You got all the supporting parts to go up a class in cylinder above the DR. So if you want to upgrade now is the time .
Post by ghostaroni on May 20, 2022 15:04:34 GMT -5
C up or down is better than side ways . I mounted my trail tech temp gauge on the vino's right under the speedometer. I zipped tied it tight it looks like it belongs there . You got all the supporting parts to go up a class in cylinder above the DR. So if you want to upgrade now is the time . Recommend me a cylinder (:
Post by ghostaroni on May 22, 2022 0:37:20 GMT -5
I have decided that after I blow up a reconditioned cylinder I had laying around; I am going to buy an MHR replica cylinder.
Post by aeroxbud on May 22, 2022 7:29:31 GMT -5
That's a great cylinder. Nice amount of power. Probably about as far as you could go on a daily rider and not have to constantly dig into the motor.
