Post by mk2rox on May 10, 2022 13:37:08 GMT -5
Buy 7,5gr rollers and put those in. i tried, goes only 65 and starts to bog full throttle
Post by mk2rox on May 10, 2022 13:37:41 GMT -5
If it Revs fast with lots of noise . No Speed What is the Last thing you changed? You stunt so check to see if you knocked off a exhaust bolt causing you to be loud and Lean. When the scooter is running with a wet rag plug the end of the exhaust. If it kills quick you are good if she keeps running you have a exhaust leak check by the cylinder first and then by silencer . I use a spray bottle with soapy water to find the leak. Your weights seem like they should be heavy enough with that set up I would crack open the cvt and have it run rev it up and visually check pulleys . . Your rear pulley could be binding not up shifting or your variator could be binding not up shifting. pulleys go up and down, exhaust doesnt leak.
Post by mk2rox on May 10, 2022 14:42:10 GMT -5
If it Revs fast with lots of noise . No Speed What is the Last thing you changed? You stunt so check to see if you knocked off a exhaust bolt causing you to be loud and Lean. When the scooter is running with a wet rag plug the end of the exhaust. If it kills quick you are good if she keeps running you have a exhaust leak check by the cylinder first and then by silencer . I use a spray bottle with soapy water to find the leak. Your weights seem like they should be heavy enough with that set up I would crack open the cvt and have it run rev it up and visually check pulleys . . Your rear pulley could be binding not up shifting or your variator could be binding not up shifting. What the fuck with small air leak it goes 78, and with that shut off it goes 68 barely
Post by Lucass2T on May 10, 2022 14:58:06 GMT -5
What the fuck with small air leak it goes 78, and with that shut off it goes 68 barely First, make sure there are leaks NOWHERE! You are running a big risk of seizing it this way. Just make sure the engine is assembled the right way. Look up the 49ccscoot youtube channel and watch some video's there. Otherwise you're just chasing your own tail and it will end up in tears.
Post by mk2rox on May 10, 2022 15:05:05 GMT -5
What the fuck with small air leak it goes 78, and with that shut off it goes 68 barely First, make sure there are leaks NOWHERE! You are running a big risk of seizing it this way. Just make sure the engine is assembled the right way. Look up the 49ccscoot youtube channel and watch some video's there. Otherwise you're just chasing your own tail and it will end up in tears. No other leaks what is going on!!!!!=!=!!
Post by Zino on May 10, 2022 16:20:15 GMT -5
What leak did you fix That slowed it down ?
Were you running too lean before ? When you are running lean you will run faster till you Burn a hole in the piston .
You have a lot of go fast parts you should dial in before you add more parts to sort through .
Post by repherence2 on May 10, 2022 21:40:12 GMT -5
bogging at full throttle in my experience is a fueling problem, either jetting or fuel delivery.
wanting to be able to "stunt" and have speed... unless you really know how to tune carb and CVT, you can only have 1 of the 2.
Post by repherence2 on May 10, 2022 21:43:19 GMT -5
kind of seems like you got the scoot, threw a bunch of parts at it and it did not end up working properly. and now you seek answers from the forum.
Post by repherence2 on May 19, 2022 0:52:16 GMT -5
do you still need help with your bike or did you get it sorted out?
...or did you end up giving up?
Post by Lucass2T on May 19, 2022 15:46:29 GMT -5
Hope he didn't take my advice and trew it off a cliff.
