Post by swayze on May 8, 2022 18:48:27 GMT -5
Hello all. Been lurking for a few months, figured I’d quit being lazy and create a user name. I’m from Alberta/B.C Canada.
Cheers.
Post by Zino on May 8, 2022 21:48:13 GMT -5
Welcome to the forum a lot of zuma builders for you to compare notes with.
Post by aeroxbud on May 9, 2022 6:11:23 GMT -5
Welcome to the forum.
Post by dvandel on May 15, 2022 22:18:37 GMT -5
Hello I'm new to this I have a 2018 tao tao scooter and it's having all kinds of problems starting with throttle response time to bad wiring for the headlights I'm kind of stump right now I'm going to check the spark plug in it tommorow to see if that's bad I'm working on getting the carb out and cleaning it to see if that does the trick I'm confused with it right now just decided to get it out tonight to try and get it running again if anyone has any ideas or suggestions please let me know thank you for your time I appreciate them all
Post by NathanielS on Jul 22, 2022 16:11:36 GMT -5
hello both of you! I'm no expert, but if it does run then the spark plug is fine dvandel. Anyways, I'm also new, but welcome!
Post by aeroxbud on Jul 22, 2022 18:14:36 GMT -5
Hello I'm new to this I have a 2018 tao tao scooter and it's having all kinds of problems starting with throttle response time to bad wiring for the headlights I'm kind of stump right now I'm going to check the spark plug in it tommorow to see if that's bad I'm working on getting the carb out and cleaning it to see if that does the trick I'm confused with it right now just decided to get it out tonight to try and get it running again if anyone has any ideas or suggestions please let me know thank you for your time I appreciate them all Welcome to the forum. You would be best starting a post it four stroke trouble shooting. Listing the problems so we can help directly.
