Post by bigmatthew86 on Jun 9, 2022 9:08:13 GMT -5
Picked up a nice 03 Vino for my lady yesterday morning. 6500 miles & it’s in good shape. It’s been de restricted & rides nice. It needs a little more power so the plan is to slap on a 70 sport kit & run the factory pipe. Tune the cvt to match & it could use some new tires so I’ll go with a 3.5x10 which should give me a little more speed. Will that setup run 45mph? Seems to want to do around 36-38 at the moment on the flat with my 265lbs.
03 Vino
Jun 9, 2022 18:34:00 GMT -5
via mobile
Post by Zino on Jun 9, 2022 18:34:00 GMT -5
You can go up a size on the back tire with out firmest issues I run a 90 90 10 Michelin s1 Your back tire will still touch ground when it is on the center stand
On the front any over size tire rubs on the shocks
36 38 sound about right for stock derestricted a 70 kit or a better pipe will put you in the 45 -50 range
03 Vino
Jun 9, 2022 20:10:12 GMT -5
via mobile
Post by bigmatthew86 on Jun 9, 2022 20:10:12 GMT -5
Would I be better off getting a malossi sport kit for the vino or picking up a s6 street race? I have a top performance black kit on my Zuma. If the street race is an improvement over it I can put the tp on the vino & the s6 on the Zuma. If there really isn’t an improvement I’ll just pick up the malossi. Can’t say I’ll never get a pipe but a kit to me is a better 1st step. Also can’t have her smoking my Zuma lol.
03 Vino
Jun 9, 2022 23:49:01 GMT -5
via mobile
Post by Zino on Jun 9, 2022 23:49:01 GMT -5
I would put both the streetvrace and top performance as faster than the malossi My wife could beat me off the line with vino vs zuma with similar malossi kits I could beat her on top end
03 Vino
Jun 10, 2022 4:13:02 GMT -5
via mobile
Post by bigmatthew86 on Jun 10, 2022 4:13:02 GMT -5
Is the street race faster than the top performance? Would be paired with a yasuni r & dell 17.5.
03 Vino
Jun 13, 2022 10:47:57 GMT -5
via mobile
Post by bigmatthew86 on Jun 13, 2022 10:47:57 GMT -5
S6 street race kit came in today. It’s going on the Zuma & the top performance is going on the Vino as soon as I have some time. Will running a stock Zuma main jet be good for the kitted Vino?
03 Vino
Jun 13, 2022 12:33:13 GMT -5
via mobile
Post by Zino on Jun 13, 2022 12:33:13 GMT -5
The stock zuma jet is a 80 tekei the vino is a 64 teikei thta is quite a big jump Try it and see
With stock airbox on a kitted vino I found 70 to 75 mikuni was a good range I found the mikuni acted one jet smaller than a comparable Teikie jet A 82 mikuni was equivalent to a 80 teike
03 Vino
Jun 13, 2022 12:33:25 GMT -5
via mobile
Post by Zino on Jun 13, 2022 12:33:25 GMT -5
03 Vino
Jun 13, 2022 13:46:33 GMT -5
via mobile
Post by bigmatthew86 on Jun 13, 2022 13:46:33 GMT -5
Sounds good. I’ve got plenty of jets just needed a starting point.
Post by bigmatthew86 on Jun 14, 2022 20:32:58 GMT -5
I started the project tonight by removing the top performance of my Zuma & installing the street race on it. Fired right up and let it get to about 200 degrees & shut it off. I’ll let it cool off overnight & snug everything up in the morning. Then it’s ride it like you stole it lol. The street race has obviously larger ports than the top performance so hopefully it’ll be a noticeable difference. Now I just have to install the tp on the Vino.
03 Vino
Jun 15, 2022 20:44:34 GMT -5
via mobile
Zino likes this
Post by bigmatthew86 on Jun 15, 2022 20:44:34 GMT -5
Got the kit installed on the vino today. Turns out 80 was my smallest jet so I have it installed right now. I ordered a few smaller ones. Also installed my factory Zuma variator, 3 shoe 105mm clutch with +500 springs, & a white contra spring. Definitely a nice boost in power but I need to get the jetting worked out.
03 Vino
Jun 23, 2022 10:00:53 GMT -5
via mobile
Post by bigmatthew86 on Jun 23, 2022 10:00:53 GMT -5
Got the 72 main jet in this morning. Installed it & took it for a cruise. Pulls way better. Didn’t have my phone with me to gps it but it’ll bury the speedo & hold speed going up hills. I’m guessing probably 45mph. I might put a wild lion on it to see if I could touch 50. We live in the country & the roads are all 55 around us.
03 Vino
Jun 23, 2022 10:54:30 GMT -5
via mobile
Post by bigmatthew86 on Jun 23, 2022 10:54:30 GMT -5
The wild lion isn’t as available. Is the polini sport or s6 street as good?
Post by Zino on Jun 23, 2022 12:03:30 GMT -5
The polini sport is the same pipe as the wild lion they are both rebadged gianelli pipes The mounting brackets can be different the lion bolts right up
The stage 6 street is as good if not better on the top end than the lion with a wide power band
03 Vino
Jun 23, 2022 16:44:14 GMT -5
via mobile
Post by bigmatthew86 on Jun 23, 2022 16:44:14 GMT -5
Awesome, I thought they looked the same. I’ve got one on the way. I’m assuming it’ll have a restictor in the head pipe that needs to come out?
