Post by FrankenMech on Jan 17, 2023 10:52:27 GMT -5
I see the forum changes moved your post to the electrics section.
I did pick up some 2" diameter 6061-T6 Aluminumium for the hub some time ago. I bought 24" of the stuff for great mistakes. It has been a LONG time since I operated a lathe. My China 7x12" unit will probably be the first to be working. I was in Walmart checking out with groceries and heard a woman trying to explain the pronunciation of Aluminum to her daughter, she was obviously a Brit.
Post by jackrides on Jan 17, 2023 13:27:13 GMT -5
Now Frankenmech, you even spelled it wrong. A L U M I N I U M.
Post by FrankenMech on Jan 17, 2023 20:32:03 GMT -5
I get cornfuzen with all of thems UK speellingses for alleuminiumin. Damn, my speeling chekers keepens redlinning ebethings. I gibt uppens. I cannst typen fer shist. Its mussen bit dis nuber redragons keybordenz
Post by milly on Jan 26, 2023 6:38:33 GMT -5
Well finally loaded and off to the blacksmith to work his magic before daughter takes ownership of the bigger car.
Post by FrankenMech on Jan 26, 2023 10:04:07 GMT -5
You had it all loaded up like that on the 16th. You have been slacking off I shouldn't talk, I am still trying to put my little lathe together. The lathe workbench is all ready to put some edging on to keep things from rolling off the top. I glued two pieces of 3/4" (19mm) plywood together to make a sturdy 1-1/2" (38mm) thick top. Then I can start bolting the lathe and a big 1/2HP DC motor to the top. It is a lot bigger than the dinky 500W motor from China. I have not figured out if I want to gear the spindle drive down. My DBS unit for my ET has a failing battery so they are getting me ready for surgery on Feb 6th to replace it. Idiot doctors want to give me anesthesia for a simple 3" incision that could be done with a local or a whack with a beer bottle. I suppose an anesthesia job pay$$ better.
Post by milly on Jan 26, 2023 14:06:08 GMT -5
Had to remove it FrankenMech to re mot the Ford Fusion for the eldest daughter to have from her mum which she buying. Good luck with the surgery.
Post by FrankenMech on Feb 7, 2023 20:52:56 GMT -5
Any progress from the smith?
Surgery was cancelled due to me having an eye infection, will try again next week.
Post by FrankenMech on Apr 15, 2023 0:29:24 GMT -5
I eventually got cut. I now sing soprano. LOL How is the project going?
Post by milly on Apr 15, 2023 6:16:16 GMT -5
Sorry not replied before FrankenMech. I took it to the blacksmith a bit ago and went to check on progress but none. I forgot to take him a 24" wheel so he can align the sidecar properly as it was on a 20" before so went and bought one.
Post by FrankenMech on Apr 15, 2023 14:39:52 GMT -5
Sorry not replied before FrankenMech . I took it to the blacksmith a bit ago and went to check on progress but none. I forgot to take him a 24" wheel so he can align the sidecar properly as it was on a 20" before so went and bought one. You b-b-b-bought one?
Are you out naked chasing butterflies again?
Somebody please find the BIG butterfly net and put him in a straitjacket in a rubber room.
This behavior can't go on, poor Yolanda.
Post by milly on Apr 15, 2023 17:01:42 GMT -5
I blame it all on the government FrankenMech. I think they have spiked the drinking water again. Next thing you know I will start believing that the earth is a globe.
Post by FrankenMech on Apr 15, 2023 22:19:55 GMT -5
Us damn colonials fell off the world. Them Australian dudes fell off first to break our fall though. At least they fell on top of those China dudes. Did all those British ships use magnets as ballast? Maybe I should have swallowed a bunch of cow magnets to keep my ass firmly planted. Governments do spike the water, why else would they keep all the pubs open?
Sorry if I make typing errors. My blood sugars are going wild and I can't see anything worth crap. I keep staring at what I type to try to make it out. I keep trying to clean my glasses. I need giant fonts. Personally I am about ready to give up and fall off the edge...
Post by milly on Jul 1, 2023 17:40:41 GMT -5
Progress so far may even run tomorrow am using the battery from the works bike for it.
Post by FrankenMech on Jul 4, 2023 15:59:19 GMT -5
TIRE SMOKE coming up!!! Just don't have controller smoke. Did the smith do a good job? I should just pay someone to make the aluminiuminum part for me but I would have to give my Scot man card back. I did get my Horrible Freight air brad nailer to work right by adding spacers to the piston bore so I can finish the lathe bench. So many mods and adjustments to make on damn China tools. It would be nice to pop something out of the box and use it. Some say I should buy American tools and products but they are just as bad or worse at 5X the cost So I buy the basic crap parts from China and paint them FORD blue since they all must be Fixed Or Repaired Daily besides being modified to work at all... Damn China crap, Damn Army, Damn Army jeep.... etc etc etc.
Post by milly on Jul 4, 2023 16:30:17 GMT -5
Tire smoke indeed just going to order up 3 sla batteries for it in a bit FrankenMech and sort them out and fire it up next week hopefully. Smith did a good job. Some exploded pics below. Got to put the 24 inch wheel in yet.
Funny you should say about crap tools took some to the festival and usually one or two disappear so bought cheap ones. The 17mm flat opened up with hardly any pressure on it. That set went straight in the garbage there and then!
