Post by RyanWiltshire on Jun 18, 2022 12:42:55 GMT -5
yesterday I had my variator, belt, rollers changed at my mates mechanic shop, bike was fine with no issues, started and rode like it did before.
next day I changed the clutch torque spring myself, took the clutch off and put the spring in for the pulley. then I went to start it with the electric starter, sounds normal, but wont actually start.
anything that I need to be checking? I looked at the variator and doesn't seem anything is wrong and the rollers are in fine. spring I changed was changed to the same brand and spring.
Yamaha Aerox
Post by Zino on Jun 18, 2022 13:31:10 GMT -5
The spring should not cause this . The Contra spring causes the contra to hug the belt enough so it doesnt slip. If you put too tight a contra in it just wont down shift as easy .
You could Retrace your steps Put the old contra spring back in
Did you knock off a ground wire to the starter ?
Will it kick over ?
Post by RyanWiltshire on Jun 18, 2022 13:35:10 GMT -5
The spring should not cause this . The Contra spring causes the contra to hug the belt enough so it doesnt slip. If you put too tight a contra in it just wont down shift as easy . You could Retrace your steps Put the old contra spring back in Did you knock off a ground wire to the starter ? Will it kick over ? there isn't a ground wire inside the transmission case. not that I can see. I have a yamaha aerox scooter.
Post by Zino on Jun 18, 2022 13:59:03 GMT -5
I have bumped the kill switch and spent a hour trying to track down a no start .
On my Yamaha vino the ground wire was held down by a transmisssion bolt just above the kick starter.
Post by RyanWiltshire on Jun 18, 2022 14:21:10 GMT -5
I have bumped the kill switch and spent a hour trying to track down a no start . On my Yamaha vino the ground wire was held down by a transmisssion bolt just above the kick starter. looked up, location for ground wire on a yamaha aerox and there is nothing. I doubt its a wire issue, I haven't touched any wires. the stator and all that is on the other side.
Post by geoffh on Jun 18, 2022 15:03:55 GMT -5
You may have missed,I have a picture of a typical variator set up I will post it when my wi fi let's me Geoff
Post by RyanWiltshire on Jun 18, 2022 15:21:12 GMT -5
You may have missed,I have a picture of a typical variator set up I will post it when my wi fi let's me Geoff nothing to do with the variator, can't be. rollers and variator are in correctly, when it was working yesterday, it was put back in from me correctly. also, not sure what you mean by "set up" only one correct way to put it back in and I have done this.
claydoh
Post by claydoh on Jun 18, 2022 15:32:37 GMT -5
Is the starter motor connecting to the bendix or whatever gear that actually spins the engine to start it? Maybe something is out of kilter, or dirty and not engaging properly.
Post by RyanWiltshire on Jun 18, 2022 15:35:20 GMT -5
Is the starter motor connecting to the bendix or whatever gear that actually spins the engine to start it? Maybe something is out of kilter, or dirty and not engaging properly. checked the idle/gear and it all seems to be fine. the crank/starter spins just fine, along with the belt and variator. I have checked the fuel filter what sits below the tank/vacumm tap, the filter seems completely empty?
Post by aeroxbud on Jun 18, 2022 16:20:49 GMT -5
Check to see if the vacuum pipe is damaged or pulled off the carb. If you suck on it fuel should flow freely from the tank.
Post by RyanWiltshire on Jun 18, 2022 16:42:03 GMT -5
Check to see if the vacuum pipe is damaged or pulled off the carb. If you suck on it fuel should flow freely from the tank. what hose am I sucking on, the air or fuel?
Post by Zino on Jun 18, 2022 17:24:14 GMT -5
The one without gas is the one you suck on coming from the petcock the fuel should pee out fast when you suck on the other tube .
Post by RyanWiltshire on Jun 18, 2022 17:28:41 GMT -5
The one without gas is the one you suck on coming from the petcock the fuel should pee out fast when you suck on the other tube . if fuel doesn't come through the filter/out the other hose, it's the vacuum causing it?
Post by aeroxbud on Jun 18, 2022 17:42:51 GMT -5
The vacuum opens the fuel petcock so fuel can flow. If you suck on it and no fuel comes out. Either the fuel filter or petcock are bad.
