Post by kevin73 on Jul 27, 2022 20:43:31 GMT -5
Hello I'm looking for information on a VIP future champion 2020 49cc/50cc. I recently purchased it used and not running. I'm looking for the spec's on it and where everything goes.
Post by FrankenMech on Jul 27, 2022 20:56:13 GMT -5
Post by kevin73 on Jul 28, 2022 5:30:10 GMT -5
Thank you sir
Post by kevin73 on Aug 3, 2022 23:53:35 GMT -5
Hello fellow scoots. My question today is do I need a bigger battery if I upgraded the stator,the rectifier, basically everything to high performance.
Post by FrankenMech on Aug 4, 2022 0:03:31 GMT -5
Probably not, but then what are you trying to do? What do you mean by 'high performance'?
Post by kevin73 on Aug 4, 2022 0:10:32 GMT -5
I'm trying to get a little bit more power and better fuel mileage.
Post by kevin73 on Aug 4, 2022 0:13:21 GMT -5
I bought everything electrical new even a new carburetor. It didn't have spark so I bought all new parts down to the stator which was the problem.
Post by FrankenMech on Aug 4, 2022 0:30:28 GMT -5
Any electrical power you produce will LOWER your mileage. The stock electrical system should be adequate for lights, starting, spark, etc. Changing things can lead to unintended consequences. NEW parts do not necessarily work. New carburetors will require tuning. Using the troubleshooting charts in the service manuals will save you a lot of time, trouble, and money. Follow the charts and do not assume anything or skip steps.
Post by kevin73 on Aug 4, 2022 0:47:10 GMT -5
Thank you sir for your input it's much appreciated.
Post by Zino on Aug 4, 2022 8:13:28 GMT -5
more power comes at the expense of fuel mileage My scooters used to get way higher mpg then mph now its about the same in the 50's for both
