zooma
Post by zooma on Aug 18, 2022 23:16:14 GMT -5
Post by aeroxbud on Aug 19, 2022 3:18:52 GMT -5
The easiest way to tell us with everything assembled up to the castellated nut. The nut should sit about 1mm over the shoulder of the crank.
Post by Zino on Aug 19, 2022 6:11:14 GMT -5
here is what Aerox is talking about www.pedparts.co.uk/blog/variator-fitting-crankshaft-pulley-spline-damageif it is too long it will push the castle nut out too far on crank. 2nd thing to check after you know it is safe for the crank is take a sharpie from edge to edge and run down road full blast and measure in mm how much is left on the outer edge of variator
Post by snaker on Aug 19, 2022 10:17:57 GMT -5
Not really sure what your concern is? Is it that the boss extends beyond the belt edge? So when the fixed sheave is installed there is a sidegap?
If so, I don't think it would be an issue of the shaft end/nut position.
That first photo would appear to be the movable sheave being too far inboard (assuming the belt width is proper) The movable sheave position is controlled by the ramp plate and flyweights.
Are the flyweights in position and the proper ones?
Not sure about all, but the drive pulley setup on my 150 has the ramp plate butted up against a very small shoulder edge of the crankshaft. Really small. It surprises my that the thing even works its so small. If yours is similar, check to make sure the ramp plate is in place and not riding up onto the next level.
Post by Zino on Aug 19, 2022 12:03:28 GMT -5
I asked my wife if my variator boss was too long She said it was just right
zooma
Post by zooma on Aug 19, 2022 12:22:24 GMT -5
Thank you guys. That explanation is very clear. I'll set this up as explained but before doing the sharpie test will have to first get the scooter running
Post by 808ministroke on Jan 11, 2023 6:17:03 GMT -5
I ask my wife if my a varieter boss was too long and she said no honeyI ask my wife if my a varieter boss was too long and she said no honey, That's why I married you....
Post by aeroxbud on Jan 11, 2023 15:52:14 GMT -5
I ask my wife if my a varieter boss was too long and she said no honeyI ask my wife if my a varieter boss was too long and she said no honey, That's why I married you.... We heard she is the boss. 😉
