Post by purvis93 on Dec 2, 2011 15:29:50 GMT -5
hey guys been recommended to join this forum so here it goes had a new era spa 50 for a couple of weeks now and it is still very much restricted wont go past 30 on a good day and 20 on a bad day! also goes up hills at between ten and 15mph was just after a few tips on deristricting and where i could get parts from im in the uk any help appreciated thanks :banghead: jack
Post by aeroxbud on Dec 2, 2011 17:25:28 GMT -5
Normally there are restrictors in the exhaust at the start of the pipe if its a standard pipe and a restrictor in the variator. The variator is normally a ring that stops the variator closing like this
lbo
Post by lbo on Dec 2, 2011 18:32:05 GMT -5
Not familiar with that scooter, my two stroke had an exhaust system that was VERY restrictive and helped with import emmission requirements here in the states. Once I took that off and put on a tuned pipe I automatically gained an additional 8-10MPH. I also had the restriction in the variator.
Look at your exhaust, see if it's one solid pipe leading to an expansion chamber or if there are various tubes that lead to nowhere or if it's connected to a pair valve system.
Post by 90GTVert on Dec 3, 2011 10:20:14 GMT -5
They've got ya covered, so I'll just say :welcome:
Post by purvis93 on Dec 3, 2011 10:35:17 GMT -5
thanks for the welcome and ive checked the variator no restriction im thinking the rollers could be worn down :/ because it bogs at high revs and hardly pulls off atall in low so 4.5-5g rollers i think but dont know where to buy them from also the exhaust is one solid pipe took that off earlier and all i could find was a washer next to the manifold took that out and it just made it really loud didnt do much on the power side
Post by 90GTVert on Dec 3, 2011 11:52:41 GMT -5
If it's a washer in the pipe then it's a restriction and should be left out. If it's a washer around the pipe you might have just removed the exhaust gasket and that's why it would be loud. A stock scooter exhaust shouldn't be loud restricted or not. If it was a restrictor, you might wanna make sure the carb is in tune. It could be lean with a restriction removed there.
Post by jmkjr72 on Dec 3, 2011 12:44:36 GMT -5
it may be loud like brent said from it being leaner or you may not have the pipe sealed properly and some gaskets do look like gian metal washers but they are larger then the header pipe
Post by purvis93 on Dec 3, 2011 13:47:38 GMT -5
the ring was smaller than the manifold and sat inside the exhaust there has been a slight power difference from a standstill up until about mid revs then there seems to be flat spots and nothing will happen :/
slawenm
Post by slawenm on Dec 3, 2011 13:54:45 GMT -5
Hello Purvis nice to see you took my advise and are getting the help you wanted have you confirmed which engine your bike is using yet by finding the markings? with you being in the UK parts help might not be suitable for you linked by the users here mostly bases in the USA. but if you get the engine type I can try find you a UK supplier
Post by purvis93 on Dec 4, 2011 17:12:58 GMT -5
thanks mate im in newcastle took my scoot over to a friends today he had a look at the engine and said the chances are its the same as a jog because they were the last minarelli air cooled engines yamaha made this is to back up a point as to why my engine has a yamaha cover on the belt housing :/ but when i got back it was running a little boggy so i thought iwould clean the carb only to put it back together to find im not getting full throttle and it wont start! made sure the throttle housing was in the right way and everything still no change :swear:
slawenm
Post by slawenm on Dec 4, 2011 17:29:50 GMT -5
ahh the members here know their way around the Minarelli engines well from threads I've read through your in safe hands!
dont know anything about two strokes so I'll let somebody else help you out.
Post by purvis93 on Dec 4, 2011 17:33:37 GMT -5
:cheers: for the recommendation to the site
Post by jmkjr72 on Dec 4, 2011 17:40:40 GMT -5
i would pull the carb out again and pull the cable off and make sure you have full movement there make sure there is no kinks any where in the cable and get it put back togehter then make sure you have full throttle movement before putting the carb all the way back in
then make sure you have the vaccum is hooked up right
Post by purvis93 on Dec 4, 2011 17:49:00 GMT -5
i one that and as i had the throttle housing out i pulled the throttle and got full movement couldnt see any obvious kinks or breaks but it did pull the spring up on an angle and also on the starting front tried starting it didnt work so put hand over air filter box and it started just revved really high maybe an airleak somewhere??
Post by jmkjr72 on Dec 4, 2011 18:04:32 GMT -5
ok so now you have it to the throttle works all the way and when it reved to the sky dod you check to make sure the throttle slide was all the way down
