Tweak09
2011 Yamaha Zuma
Post by Tweak09 on Dec 4, 2011 14:21:57 GMT -5
I have not seen that. I got till Tuesday to figure something out before I take it to the shop. Could you show me a link of some sort? Would a spare tire work haha.
Post by 90GTVert on Dec 5, 2011 9:42:17 GMT -5
Tweak09
2011 Yamaha Zuma
Post by Tweak09 on Dec 5, 2011 10:29:30 GMT -5
Right on. Sadly I can't even break the nut loose. I've thrown it into a vice and everything. I'm a little dude haha. About 150lbs but when I was trying to break it loose with a pipe wrench I was doing harm then good. I fear I'm going to end up rounding the edges of the nut since it's a soft metal. If I do that I'll end up with another problem on my hands. My clutch has never been opened so this is factory tight. May just take the clutch itself and see if a shop will break it loose for me.
Post by Goosey on Dec 5, 2011 10:38:42 GMT -5
It's usually just the pressure from the spring holding it tight, so compressing it down with the tire worked for me just fine on a couple different clutches, without pre loosening on the vice. Probably it's like that odd flywheel that just won't pop That reminds me I need to keep at least 1 of the scrap car wheels in the clean up pile from my garage demolition...I'm a little girl, 115, LOL. Thanks for the video Brent. I couldn't find it
Tweak09
2011 Yamaha Zuma
Post by Tweak09 on Dec 5, 2011 10:48:33 GMT -5
Well now I feel weak :laugh: This thing has got me beat though I'll admit it. With a broken middle finger it doesn't make the task any easier either. Thanks for the help though. Kudos for giving me some how to's I had never seen.
Post by Pony66 on Dec 5, 2011 11:16:36 GMT -5
Well now I feel weak This thing has got me beat though I'll admit it. With a broken middle finger it doesn't make the task any easier either. Thanks for the help though. Kudos for giving me some how to's I had never seen. Try to find a piece of pipe to extend the handle of your wrench. Perhaps borrow a breaker bar and 28mm socket from a friend or go play Santa at a pawn shop.
Post by 90GTVert on Dec 5, 2011 12:09:18 GMT -5
I think that's a typo above, should be 38mm socket unless the Zuma is diff than the other minarelli 2Ts. A shop would probably do that super cheap too if you take that and ask for them just to remove the nut.
Post by jmkjr72 on Dec 5, 2011 19:44:15 GMT -5
yeah i think its 38 irrc i use an 1 1/2 socket some of them i have had to use 1 5/8 or 1 11/16
